20 Most Recent Xerox Phaser 850DP Thermal Printer Questions & Answers
That's normal for any printer. It's trying to pick up the printing of the entire document.
If it didn't print the same page again after you clear the jam, you would be missing a page.
Xerox Phaser... | Answered on Apr 14, 2011
If I remember correctly, disconnect the print cable, then reboot the machine.
I saw that problem once and its been a while, but I do believe thats how I finally got it to stop.
Then clear out the print queue.
Xerox Phaser... | Answered on Mar 31, 2009
either the paper pulling gears are not spinning properly or they are craked or getting blocked by any dust particles.
or the fuser unit in the copier is not getting properly heated up.fuser unit has to be checked first before replacing and the printer /copier needs to be opened to check the fuser unit.
Xerox Phaser... | Answered on Feb 26, 2009
That is a yellow ink stick count fault.
Most likely one of the yellow sticks has just gotten twisted in the loader and not advancing. May be cracked or damaged but for some reason not sliding down to the bottom and hitting the sensor.
Check the sticks and if you need to remove them just take a screw, like a drywall screw and twist it into the block to remove it.
If you managed somehow to get a stick in the machine from a different phaser product, it is shaped different and would not actuate the switch at the bottom of the ink loader.
Xerox Phaser... | Answered on Aug 04, 2008
Try this link:
https://www.support.xerox.com/en-us/article/en/1551565
Xerox Phaser... | Answered on Feb 08, 2020
Please check the HD & RAM.
Xerox Phaser... | Answered on Apr 12, 2019
I suggest You Go to Official Xerox Printer Page For You Xerox Printer Problem On Below Xerox forum URL Link: Clearing Paper Jams In Case You Still face Problem and Need Online Assistance Then Please Follow Us For On :
Xerox Printer Support
Xerox Phaser... | Answered on Aug 20, 2018
Have you tried replacing the whole drum cartridge?
Xerox Phaser... | Answered on Aug 04, 2018
What model do you have?
Xerox Phaser... | Answered on May 01, 2018
Xerox Phaser 850DP Thermal Printer Logo
7 questions posted
Top Xerox Office Equipment & Supplies Experts
Tareq Bin Mostaq...
Tareq Bin Mostaq...
CheckitRight
CheckitRight
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
Phaser Xerox
  • Phaser Xerox
Most Popular Question
xerox 8560 37x fault code
  • Office Equipment & Supplies
