20 Most Recent Xerox Phaser 4500 Printer Questions & Answers
check your supplies status check job status
Xerox Phaser... | Answered on May 24, 2018
this machine has the option of metered or non metered toner (sold toner)
are you under a contract ? did you just acquire this machine?
Xerox Phaser... | Answered on May 18, 2018
U5 00 SPF COMMUNICATION TROUBLE
U5 16 SPF FAN MOTOR TROUBLE
U5 30 SPF TRAY LIFT-UP TROUBLE
U5 31 SPF TRAY LIFT-DOWN TROUBLE
U5 40 SPF INSTALL TROUBLE
For more help visit cbr tech solutions
Xerox Phaser... | Answered on Nov 23, 2015
Sounds like something stuck on a roller with a diameter of ~1/2" diameter.
Good luck.
Xerox Phaser... | Answered on Jul 03, 2015
Replacing the fuser will fix that. Or if you want to strip it down check the lamps and if they are ok change the thermistor and thermostat. But your better off just replacing the whole unit'
Xerox Phaser... | Answered on Apr 26, 2014
Hi Nickolas,
You may want to visit this site that has a manual of your machine in order for you to check the reset process. Hope it helps.
Kyocera KM 1500 KM CS 1500 Operation Guide Rev 2 0
Xerox Phaser... | Answered on Apr 25, 2014
You would have to replace the fuser to resolve that code.
Xerox Phaser... | Answered on Apr 24, 2014
If you remove the toner cartridge and gently shake it side to side, then reinstall it, does the problem go away, or come back after a few pages? I would suspect you have a bad toner cartridge/image unit and recommend you put in a new one.
Xerox Phaser... | Answered on Mar 16, 2014
You can try inspecting and moving the ram to the other RAM slot. The 4510 image processor board has 2 ram slots, so one of them should still be unused. To access the ram you must remove the right side cover. Its possible changing the slot the ram is in will fix this, if it does not the next step would be to replace the ram. Part# 133K27760 for 128MB. Finally, if after replacing the RAM the error continues you would need to replace the image processing board. (part# 960K41806). Hope this helps
Xerox Phaser... | Answered on Mar 03, 2014
No you have to replace it otherwise you get bad quality
Xerox Phaser... | Answered on Jun 26, 2013
74 questions posted
Top Xerox Office Equipment & Supplies Experts
Tareq Bin Mostaq...
Tareq Bin Mostaq...
CheckitRight
CheckitRight
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
Phaser Xerox
  • Phaser Xerox
Most Popular Question
fuser error code u4
  • Office Equipment & Supplies
