20 Most Recent Xerox Phaser 8200 Laser Printer Questions & Answers
Your first choice - from bottom left hand corner upwards is better,
luciana44
Xerox Phaser... | Answered on Nov 28, 2019
That sounds like one of two things.
Either the ribbon cable to the screen needs reset, you have to remove 4 screws I believe it is, then unplug everything to that assembly, and re plug them back in.
If that does not repair it, then most likely the electronics module has failed. That is quite expensive to replace.
Xerox Phaser... | Answered on Jul 03, 2019
Hi Shrife,
Although you might have this problem cleared by now, Ill try and add more information that might be of help.
Once you replace the maintenance kit there is a small CRUM Chip on the side of these units to record the life of them and can be used monitor how long units have been used for then the printer can remind the user when to order a new unit.
If you have a bad connection then the unit won't register and work.
If you have a faulty unit you must let the supplier know and they should send you another.
Good Luck.
Xerox Phaser... | Answered on Jul 03, 2015
Not a problem, but turning it off causes the machine to do a setup, which then purges the ink supply and is very wastful.
Xerox Phaser... | Answered on Mar 11, 2015
From the service manual:
PM_FAULT_DM_CAM_
POSITION_ERROR
The Drum Maintenance home sensor actuated, but not at the
expected time. Inspect the maintenance drawer lift pins for wear.
Run diagnostics to verify clutch and sensor operation. Also verify
that the drum maintenance shaft is properly assembled.
If you need the SM, let me know and I'll shoot it out to you. Thanks and please take a moment to rate as fixya.
Xerox Phaser... | Answered on Nov 11, 2014
First of all Printer's service
then see what is flashing in your printer's screen
Xerox Phaser... | Answered on Feb 14, 2014
Try a brand new document and cover the page in characters and test print. If the issue persists, then please call for service.
Xerox Phaser... | Answered on Nov 29, 2013
its crazy we just had one the other day that was acting up. If you have a spare control panel try switching it, look for any lights. If you know your control panel is 100% good. Then you might have to end up switching the power supply.
iteminconline
Xerox Phaser... | Answered on Nov 06, 2013
Generally what causes this is a blockage of the laser beam. Check that the toner/drum cartridge does not have any foreign paper stuck to it. People some times stick a date on them and this impedes the laser beam ray.
Xerox Phaser... | Answered on Nov 03, 2013
Clean the pick up rollers with alcohol. They need to be really grippy.
If it's folding the corner of paper I expect there is a bit of torn paper stuck in it.
Xerox Phaser... | Answered on Oct 29, 2013
something with the heating of the drum.
Considering the age of the machine, I would buy a new one. Probably cheaper than fixing it.
Xerox Phaser... | Answered on May 31, 2013
something with the heating of the drum..
I think it's easier to just buy a new printer considering the age of this one
That actually should make magazine quality color.
What are you experiencing? Do the colors not match? Are there smears or light streaks?
I will gladly work with you to revolve your problem, I just need a frame of reference to start.
Let me know.
You may simply need to download and install a different driver.
They are on www.xerox.com you should be running the PS version of a driver for better graphics.
Xerox Phaser... | Answered on May 03, 2012
Xerox Phaser 8200 Laser Printer Logo
Popular Tags
175 questions posted
Top Xerox Office Equipment & Supplies Experts
Tareq Bin Mostaq...
Tareq Bin Mostaq...
CheckitRight
CheckitRight
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
Phaser Xerox
  • Phaser Xerox
Most Popular Question
re phaser 8200dp solid wax printer very
  • Office Equipment & Supplies
