20 Most Recent
Canon REBEL T2i EOS 550D Digital Camera with 50mm lens Questions & Answers
How to convert my raw images
Photoshop, GIMP, Rawtherapee, Darktable, Lightroom, etc...
You can even do it in batch with linux.
But I recomend to set the camera to jpeg+raw and let the camera do the conversion for you. Then if you need an special retouch of a photo, use any of the above applications.
Canon 55o d will not turn on
Try another battery first. Many of the cheap Chinese batteries won't hold a charge.Otherwise it sounds like you might have water damage to the circuit board that his shorting out the battery
Canon EOS 550D won't turn on
If you have Magic Lantern installed on your camera and it won't turn on, all I had to was re-format the SD card. Works perfectly now. You just need to get rid of ML.
I have heard that Digital cameras have a limited
Any mechanical device will eventually wear out, and a DSLR has many moving parts. The shutter and the mirror mechanism are prime examples, but in addition there are buttons and dials.
There's nothing in the camera keeping track of the date or number of pictures and then stopping operation when some limit is reached. In normal operation, the camera should be good for years and/or tens (or hundreds) of thousands of pictures.
CANON REBEL XS
It can happen if you are in the Auto-No Flash mode. Or if the flash release button is stuck.
Contact customer service, and have a pro take a look at your camera.
Trying to download pics from computer and get error 31, but then camera automatically disconnects itself
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo management program such as Picasa.
Organize edit and share your photos
Liquid soap inside the screen
The soap is probably between the back light and the LCD itself, on one of the plastic Fresnel screens. You may be able to clean it off with Windex on a Q-tip. Remove back cover (can't give directions without knowing which model)
Focus lights are Dim on My 1100d
Remove black side cover (two screws) and rear cover and check the rear circuit board for a missing screw in the lower right corner. Find screw and replace. If it did not short out the circuit you should see the function return. Other, send to Canon for circuit replacement
