Hook up the USB cable to the computer and see if it recognizes the phone, if it does just download the pictures like you do from any digital camera. I just did this with my Galaxy Note.
Hi Brian when you go to login to facebook and forgot your pass word there is another button there that says "forgot password" Just click that... CHEERS..
if you go to YOU TUBE and type in the search box your Question some video's will appear and one of them should sort out your problem it worked for me a few times with different phones and Tablets . Hope this helps .
It is very simpel. It is very easy to think of one thing that you know very well. Some words, such as street names and to replace the letter "E" number 3. This is the word that you do every day of the stem you must have eyes in the front, for example, when you go from there along the street or someone familiar with your lives there.
Is this the one you have? If not what size screen does it have?
is there a model number? Support Wi Fi Tabs SM T210R Samsung Galaxy Tab
This is the link where you can download all the manuals for this version.
Go to the Google PlayStore App on your tablet and download & install the Facebook App that is if you don't already have the Facebook App because it came Pre-installed on your tablet.
Do NOT sign up for a new account.
Sign in with your Account ( the one you already have) and add it to your tablet.
If you need more assistance, do not hesitate to write back in the COMMENT Box and I will further assist you.
Have you tried a different charging cable?
Did you allow the battery to run down until it was completely drained?
- If so then try the following;
Watch this video (link below). You should only remove the back cover, disconnect and reconnect battery cable. Disregard the rest of the video as I could not find one doing ONLY what you would need to do. Follow the instructions to remove the back of the tablet then disconnect the battery cable(careful not to damage the circuit board), reconnect the battery cable, and replace the back cover. Connect the charger, within a minute the screen on the tablet will pulse/flicker which is good news, allow it to charge a while, turn on the device, turn off the wireless wifi, click the power button to turn the screen dark again, and allow to charge for another 6 hours or till fully charged (when not connected to wifi the background processes will affect the charge time, on a weak charger it may not even charge like from an usb port on a computer).
Again, you should only be concerned with the video up to about the 1 minute and 15 second mark. You only need to disconnect the cable then reattach it. ONLY DO SO if you are comfortable doing so. If you have never worked on electronics before or are uncomfortable find someone to do it for you.
Galaxy Tab 3 Battery Replacement and Screen Repair Disassemble and fix
