20 Most Recent
Kyocera FS3140MFP AllInOne Laser Printer Questions & Answers
Fs 3140 mfp error
Can you be more specific or provide error codes or messages?
5/5/2019 9:26:17 AM •
Kyocera...
Answered
on May 05, 2019
Error type :setting
if scanning to email it means you have one or more smtp settings wrong usally its the host address or authentication user and pass
if its to folder its either the ip of the computer is wrong or the login info is wrong
8/11/2014 12:46:48 PM •
Kyocera...
Answered
on Aug 11, 2014
FS3140 memory full
this can occur if jobs hang due to printer error (empty toner, jam, etc...) if the printer usually prints normally but displays that message when faxes are being received then you may need to reset or replace the fax board and update the firmware. you could turn on hdd RAMDISK mode in the command center. You could also add additional RAM
1/2/2014 1:21:35 AM •
Kyocera...
Answered
on Jan 02, 2014
Turn on confirmation page
you need to turn that on at the control panel. you cannot toggle that option in command center rx
12/26/2013 8:53:37 PM •
Kyocera...
Answered
on Dec 26, 2013
Printing from auto feed leaving lines down side of
if you mean making a copy from the automatic document feeder check the slit glass (the thin narrow glass beside the big platen glass) for debris, white out, dirt, etc... a small dot on that glass will make a line on the copy.
12/26/2013 8:44:16 PM •
Kyocera...
Answered
on Dec 26, 2013
