20 Most Recent GE Nx1300e Led Network Keypad Nx1300eled Questions & Answers
0answers
GE NX-1300E
this kind of issue is usually caused by either a logic fault or an issue on the main board.Look for a defaulting switch on the board. remove ALL power, press and hold the switch and restore power, this should default the board back to factory settings. You will have to reprogram the system so take note of what areas are assigned to what zones..Make sure the power pack is supplying the correct voltage too, check on the pack for its output and make sure the same supply voltage is reaching the board.Also, check for blown or damaged fuses as the keyad should have its own fuse, check these electrically - looking to see if the fuse is damaged is not sufficient, check to make sure it has continuity with a multimeter and be careful if you try using a normal test probe as these can cause issues with digital circuitory.
2/15/2012 2:05:13 PM • GE Nx1300e Led... • Answered on Feb 15, 2012
Motion detector is not working for GE INTERLOGICX 60-806-95R
All wireless security motions have a 3 min delay built into them. This means that whether the alarm is set or not when the motion detector picks up motion it shuts down for 3 min and will not pick up motion. This is done to conserve battery power. So I always advise customers to arm the system and stay away from the motion for 3 min total. example: 60 sec to arm system + 2min wait time. then try to trigger motion. If this does not help and assuming batteries are good, you'll need to replace motion. Good luck. This may help https://al.ly/vR54zP
12/15/2019 10:15:53 PM • GE Home Security • Answered on Dec 15, 2019
Locked In! GE SImon XT Doors & Windows - not taking code(s). Code(s) work to set date/time, but when trying to disarm "doors & windows - no entry" condition, no code works. No characters display.
I would start by power cycling your system. Remove the battery & power. After waiting 10 minutes or so reconnect the battery and then power. Other than that you need to be a bit more specific with your issues.
5/3/2019 7:01:09 PM • GE Home Security • Answered on May 03, 2019
Ge security system says service and the red fire light is on but there is no fire.
Try disarming system twice to get the fire zone to reset. If that doesn't work, try to downpower the entire system, including back up battery then re-power the system with the back up battery first.
10/24/2018 1:30:36 PM • GE Home Security • Answered on Oct 24, 2018
How reset dvsr admin password to default settings
First of all, here is the direct link to the ONLINE USER'S MANUAL for that model:
http://www.novisec.nl/cms/component/option,com_docman/task,doc_view/gid,67/
To view the Owner's Manual with Operating Instructions just use your mouse to click on the link, which is the underlined and highlighted text just above. This will open a new web browser page automatically for you and allow you to view the information at the website indicated and the contents of the Owner's Manual.
You may need ADOBE READER installed on your computer to read PDF documents. You can download this free at WWW.ADOBE.COM if necessary. Click on the DOWNLOAD ADOBE READER button on right side of the ADOBE home page when you get there, and then just follow the onscreen instructions to install it.
See page 17 of the ONLINE USER'S MANUAL for detailed instructions on how to reset the unit to default settings. Basically it says:
Push the MENU button, select admin and enter 3477 for the password, then press OK to confirm.
Use the arrow keys to navigate to UTILITIES, then press ENTER.
Then navigate to RESTOREPARA and press ENTER.
Then select OK to confirm and the system will automatically reboot.
Please comment back here to this page if you have any questions, have difficulty accessing the links, or just require further general assistance and I will respond as soon as I see it.
Thank you very much and good luck.
Joe.
10/8/2018 12:05:04 PM • GE Home Security • Answered on Oct 08, 2018
Hi, i have a ge simon xt alarm... i want to disconect one of the sensers...it wont let me do that...what do i do?
you need to get the installer code, then enter programming mode to delete the sensor.
3/28/2018 5:17:08 PM • GE Home Security • Answered on Mar 28, 2018
Cannot log in to web interface for DVR30 with IE 9
Try updating IE to the latest version if not you can try firefox or google chrome check the manufacturers docs to see if they require a certain web browser.
8/30/2017 10:16:59 AM • GE Home Security • Answered on Aug 30, 2017
GE Nx1300e Led Network Keypad Nx1300eled Logo
11 questions posted
Top GE Home Security Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a GE Home Security Expert? Answer questions, earn points and help others
View Most Popular
GE Home Security
  • GE Home Security
Most Popular Question
ge nx 1300e
  • Home Security
