20 Most Recent Night Owl Optics 8 CHANNEL H264 DVR WITH 8 CAMERAS Questions & Answers
The default password for this unit is 111111
If you have set a different password and cannot remember this you must contact the Night Owl technical service department directly for a factory reset. There is no other way of accessing the unit if the default password has been changed and you have forgotten it.
In the event that the default password is changed the contact details for Night Owl Technical support as follows;
Night Owl 75 West Street Walpole. MA 02081
Toll free Phone : 1-866-390-1303
Website: www.NightOwlSP.com
Email: Support@NightOwlSP.com
Hope this helps. Please remember to leave a vote for the solution. Many thanks.
Night Owl Optics... | Answered on Sep 17, 2019
By trial and error I guessed the telnet password. I found a not that said it's running a version of Linux.
Here ya go!
regular telnet (not ssh)
root/123456
Night Owl Optics... | Answered on Aug 25, 2013
If your monitor is showing 'video loss' on each of the eight camera windows then the problem lies between the camera connections on the back of the Recorder and each camera. Without knowing what partially uninstalled means the troubleshoot process would be:
1. Use a voltmeter and check the camera power supply(s) line adapter where it splits to feed the cameras for full voltage- your unit should show 12Volts DC. Lack of voltage here and the cameras will not have power and cause 'no video' to the recorder.
2. Check the recorder menu to make sure that all camera inputs are turned on and are set to record. 'Covert' or hidden screens may not be viewed on a monitor but might show 'loss of video'.
3. It's highly unlikely that all cameras would fail at the same time so 1) if there is power and good video cable connections at the cameras, the next check would be to : 2) check each video connection into the back of the recorder and make sure that they are on camera "input", and not on a 'loop out' terminal by mistake.
If the above checks do not determine the fault, you would have to somehow feed a known good video signal into one of the camera inputs on the recorder and then troubleshoot the recorder.
If you repost what you have confirmed working we can re-assess.
Night Owl Optics... | Answered on Jan 25, 2013
Night Owl Optics 8 CHANNEL H264 DVR WITH 8 CAMERAS Logo
31 questions posted
Top Night Owl Optics Home Security Experts
Bill
Level 1 Expert
Lawrence Oravetz
Are you a Night Owl Optics Home Security Expert? Answer questions, earn points and help others
View Most Popular
  • Night Owl Optics Home Security
Most Popular Question
night ow dvr forgot admin pwd
  • Home Security
