20 Most Recent
Frigidaire FAFS4272LW Washer Questions & Answers
When the washer is turned on how do I get it to move from sensing?
Good Afternoon Friend,
I understand that when your Frigidaire washer, model# FAFS4272LW, is turned on, you are having trouble with it moving from sensing. Your washer should be sensing how heavy the load is for a little bit and should then move on to the next point of the cycle. If not, I suggest resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Once power is restored, try running any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Fafs42272lwo says door open when closed
Hello Craig, thank you for your post!
I understand that the door of your Frigidaire washer (FAFS42272LW) indicates that it is open and your washer will not operate. Let's try resetting your washer by either unplugging it or flipping the household circuit breaker off. It is best to wait roughly ten minutes and then turn on your washer. Select a normal cycle and verify if your washer will start. If yourappliance will not operate then it possibly have a faulty door lock assembly or a communication problem with the control board. I am fairly confident that an authorized service agent will be able to restore your appliance to its normal operating condition. You can often locate a qualified service technician on the manufacturer website.
Thanks for allowing me the opportunity to assist you! - Z
Fafs4272lwo parts diagram
go to youtube and look it up. Basically, you take the top off follwed by the control panel and the front. It is very easy to do.
My washer won't spin
Hello Michael Johnson - Does the unit make a humming noise? If so, either the drainage hose/pump is clogged and needs to be cleaned. If not, the washer may possibly be experiencing an issue with the door lock assembly, faulty pump, timer or control board not communicating correctly. Contact a professional to move forward accurately to properly diagnose and repair the unit.
How to replace the pump in a Frigidaire fafs4272lw washer
Hello - They pump looks like an elbow type connector and it is located underneath the unit on the bottom right. However, if you are trying to replace or repair the pump, contact a professional technician to move forward accurately since the information is not available due to liability reasons.
Where is the pump location
It may look like an elbow type connector and it is located underneath the unit on the bottom right. However, if you are trying to replace or repair the pump, you might need to get a professional technician.
Fridgidaire fafs4272lwo door open error
Make sure the latch is not broken on the door. Retry. If this continues contact a professional so the latch and door assembly can be diagnosed. Also check to see if the door is sagging down at all.
My Frigidaire Affinity washer makes a loud buzzing sound when you push the start button and will not start, what can I do
Good Morning Anonymous, this is Z. I am happy to assist you!
I understand that your door indicates it is open and your dryer will not operate. Let's attempt resetting your dryer by either unplugging it or flipping the household circuit breaker off. It is good to wait approximately ten minutes and turn on your dryer. Select a normal cycle and verify if your dryer will start. If your dryer will not operate then it possibly have a faulty door lock assembly or a communication problem with the control board. At this point, it would be advisable to contact an experienced appliance repair tech to assist further.
