20 Most Recent
LG WT5001CW Washer Questions & Answers
How do I take the bleach dispenser out of my top load washing machine.LG WT5001CW
Hello. The bleach dispenser cover(the part you see) un-snaps and lifts out revealing the dispenser assembly beneath. The part number for the cover is MBL62061401 and the dispenser assembly is ACZ72910401. Why are you taking it out? If there is some leakage down the front of the machine, make sure the washer is VERY level as the basket/tub ring will lean towards the side that is lower. Check the suspension rods for wear by placing your hands on the right and left side of the tub ring(the white circular cover over the spin basket)and shove smartly downward and let go. The suspension rods should grab going down and pull coming up--no "hobby horse" wiggling/bouncy movement at all. They act just like shocks on a car--if you push down, the car will come up and immediately settle. The suspension rod part number is 4902FA1665W and you will need to change all four if any corner is worn. **To access the rods and dispenser assembly, you must use a 2 inch putty knife, insert is approx 3-4 inches(use a flashlight to help you see) from the right and left side *front*. There are 2 steel clips that hold the top cover tightly to the washer frame. You have to push them in while pulling the top cover towards you and up. Place your hand inside the lid and grab the top cover tightly at the front right and left sides--the clips can be really tight and difficult to get released so be patient. The top cover will hinge up from the back. Be careful--some models have screws at the *back* corners of the top cover that have to be removed. I hope I helped you!
What does load sensing mean
Load sensing means that the machine will automatically set the load size determined by the weight of the load at first fill.
No Power
Check the main board power if there is power to the main board indicated by the lit LED then we would have to move forward from that point with testing, do you have a multimeter?
My two year old LG Top loader washer wt5001cw
Use a putty knife to lift top. Insert between cabinet and top in front. There is one on the left and the right. Then the top should lift up and be able to at least get your clothes out.
