20 Most Recent
ASUS GeForce GTX 550 Ti 910MHZ PCIE Video Card PCI Questions & Answers
Dell precision 390
Hi , just wondering whether you connected the 6pin pci-e power supply to the video card
also is a GTX650TX series model rather than your noted GTX550TI
I recently built a computer for my friend.
Test all leads that attach from motherboard to hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure dust free connections and are not faulty or just replace them they might be faulty
even something as small as an electrical fan and its lead can cause you problems or just replace them they could be faulty a computer needs all electrical power and data to continue through every working device and to have an end so any faulty leads will end up with a computer error Click start control panel administrive tools computer management device manager scroll to display adapters + to expand you might see a yellow question mark ? or exclamation mark ! or a red x right click select reinstall drivers also you might uninstall the display adapter restart your computer then reinstall the display adapter and its drivers this would apply to the sound video and game controllers hope this helps
My pc was very fast....but
Speed up your computer by:
-- cleaning system junk
-- optimizing computer services
-- optimizing internet
-- repairing registry
-- defraging registry
-- clearing browsers junk
do these things with some secure tool such as Intel Software Partner Reginout.
DRVER CRASHED LESS THAN A WEEK AFTER INTALLING LATEST VERSION OF DRIVERS [NVADIA GEFORCE 8500GT] 512MB
Did you try to play games for a long time, with the stock cooler.
i'm amazed about all the gammer which are still using stockcooling and the teperature stays warm for 5 hours. And if i say they need to watercool it, just like you cpu and memory, because high temps degrease 1. the lifespan of your gear ( especially mb with cheap capacitors) enemoursly, but they overclock the graphiccard at the same time , while the effectivity decreases , caused by too warm components, they want also higher ratings from the card by overclocking. That's why i never by second hand cards or mb's or cpu's. Does the card still work; if not, does it smell burning? and did it broke, while gaming?????
Horizontal streaking and color distortion
Check very well that the connection of the connectors is right: push the videocard lightly onto the motherboard, with a little wriggling.
Maybe remove and clean connectors with alcohol and then reput it in.
Also check the powerline connector very well.
if this is of no help, I am afraid it is broken.
My VGA has been corrupted. How can I fix it?
Hi , I suggest to check for any thermal issues including condition of the video card fan / heat sinks ie dust ,
If supported you can run a LINUX disk like Ubuntu in live / try mode
If video works ok , then most likely a Windows environment incl hardware conflict or virus / driver corruption issue ,
but if not then most likely a video card hardware issue like bad card cooling fan or excessive dust - thermal shedding issue or card bios/chipset fault
If a likely software issue then uninstall and then reinstall the video card
Consult ASUS or Nvidia support
The procedure is something like this
Onboard video support ?
yes
uninstall the video card driver and any video vendor configuration applets
Uninstall video card in device manager if still present.
Shut down and remove mains power cable
remove the hardware video card ,
(using anti static electricity procedures)
Attach onboard video to display
Power up and enter and configure BIOS setup if required, ie 1st seek onboard video
Bootup to Windows
Install the onboard video device
using Windows plug&play default driver executed during booting
Restart
Confirm working ok
Update the chipset driver (inf) if applicable,
restart
Shutdown
Reinstall the hardware video card
Attach to display
Reconfig BIOS setup if required
Start to install default driver
Install video driver / update from card default using a known good driver whose setup file has been previously downloaded
restart and test
Hope this helps
Pnpdrivernotfound windows 7 x64
Try the ASUS website for the driver. If that is what you are looking for. (It even tells you in the information you provided.)
Nvdia 9400 gt on P5GD1-TML/S
Yes, your mainboard supports up to 2GB of DDR memory. That does not change if you add a graphic card. Windows XP 32 bit can actually address up to 4 GB of total memory including CD, hard drives, and video cache. Note: Your mainboard only supports up to 2 GB, but newer boards can support much more memory, up to 16GB of RAM.If you could install 4 GB of RAM in your machine, it would still work, but windows would only address as much RAM as it can use; the rest would go unused, so it would probably show up as 3.5 GB of RAM then.
