20 Most Recent
Umax MaxMedia TV II Plus (MTMD-83611) Questions & Answers
What is MAxmedia tv for?
its a VGA to s-video/composite(rca) converter. it allow you to connect a computer to a tv with compatible inputs. Example would be to connect your laptop to a tv to show videos or pictures at a family gathering. you connect a VGA cable to the VGA output on the laptop(usually blue) connected to the
MaxMedia TV II Plus, then from there you could connect a set of rca to the tv and view whatever the laptop sees on the tv screen with audio.
another example with a diagram
hope this helps
In my laptop operating system
it may require additional drivers(usually sepplied with the products if neede)
can also get from the website of the provider
I lost my cd drive
Google is your friend. Google the model number and you should find a link to a driver.
Drivers
If you were to log on to the
manufacturer's web site, I think you will be pleasantly surprised as
usually one is able to download, by model number, Customer
Instruction Manuals, list
of Dealers for spare part supplies and Driver
downloads
as required.
Just Google the manufacturer's name and
follow the links. Make certain you are directed to the manufacturer's
web site as some search engines direct you to other sites and they
charge for the information that is normally free of charge.
I hope this helps.
I bougt tv tuner card
Most often there is not much that can be done on the tuner card except if there is the failure of the tuner which can be changed with a chance.If short circuit it is easier to find as checking with a meter to see if it is a regulating device that can be changed easily.
If not since you need the use of one , you will have to buy a new one.
