20 Most Recent
Samsung Cht 335 Cell Phone Questions & Answers
I want a cartoon themes
It doesn't support themes. Only Samsung Z series and Samsung GT-S5230 Star; Samsung GT-S5233Tv; Samsung GT-S5560; Samsung GT-S5620Monte supports themes.
Cant send message on my samsung S3353 but i can call, received text and call..
for sending text messages :1.go to your message settings and check the message center number to see if it is correct2. call to your network operator customer care3. request the message center number...4.note it down5. go to message settings>message center number6. insert the number which is noted by you and save itthis solves your messaging problem ...Good luck
My samsung Gt-s 3353 does
You need to convert the video you wish to play to make it such as AVI file so that you can play it on your phone.
Download this Video converter,install and run it in your computer,then enter the video you wish to convert and then place the converted video on your memory card then play it.
SAMSUNG VIDEO CONVERTERThank you for choosing Fixya....
My samsung ch@t restart every time y turne it on,dont let me go to settings,what y do to resolve it?
mY Dear:First:restore your Phone SettingsIF Restart problem not Solved So Secend Option:Please Format Your Phonewe can solve this problem but i need you to backup the whole DATA that you have in the phone and perform this reset procedure.*#7370# or *#7780#Default security code is 12345release some memory then it will b opened your phone or memory card get attack by virus. pls do a format phone and memory card.If Problem Not Solved SoVery Best Solution:flash new software install in the phone problem will solved quickly
How do i connect my samsung 335 phone to my computer
little, you need to go to samsungmobile.com and download the samsung pc suite and launch it after this connect the device it find automatticaly,then it ask on device to connect and select pc suite mode, once finish connecting ,then sync the device and now is ready to use for transfer data, Best of Luck
