20 Most Recent Umax PowerLook 1100 Flatbed Scanner Questions & Answers
I have used a UMAX
Welcome to Fixya. With the issue that you have there can be 2 possible source of the problem the Firewire Converter or the Port. For us to make sure which is the cause we need to test if first. Since that it is working fine on the old iMac it only means that the scanner is fine. However for us to test if the problem is the port or the cable the only way you can do it is to either use a different Firewire 400 to 800 or use the Firewire 400 ot 800 and the scanner on a different machine. After that we will be able to know which is causing the issue
If you have questions please let me know. Thanks for using Fixya
4/16/2011 8:13:35 PM • Umax PowerLook... • Answered on Apr 16, 2011
Magicscan not working with umax scanner II .
Magician 4.5 is available at UMAX Official Site.I recommend that you visit Umax site and download the latest available drivers/software and install them. Also, there is a registry fix available, which may solve the issue.
Good Luck!
Hope this helps!
CreativeTECH
12/22/2010 7:16:18 AM • Umax PowerLook... • Answered on Dec 22, 2010
4answers
Umax Powerlook 1100 with Mac OS 10.5?
Long ago I had to resort to a third party scanning software, called VueScan from Hamrick Software. Works just fine now.
4/9/2010 10:38:34 PM • Umax PowerLook... • Answered on Apr 09, 2010
I need to run my
You need to buy IEEE1394 Firewire.
You could purchase it from :-
http://shop.ebay.com/i.html?_nkw=ieee+1394+firewire+cable&_sacat=0&_odkw=ieee+1394+firewire+2+pin&_osacat=0&_trksid=p3286.c0.m270.l1313
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
3/20/2010 11:30:01 AM • Umax PowerLook... • Answered on Mar 20, 2010
3answers
Powerlook Umax 1100 Flatbed scanner & Mac 10.5.5 Driver's..?
Looks like they'll let you buy Silverfast SE for just ... $49. Wow. Expensive price for just a driver.
On the premise you may not need the Silverfast software per se, just the driver, you may be able to, after investigating the legality, try a demo version of a Silverfast product and see if you can keep the driver itself after you get uninstall Silverfast.
http://www.silverfast.com/get_demo/en.html
2/20/2010 12:28:43 AM • Umax PowerLook... • Answered on Feb 20, 2010
Ihave a Umax Power Look 1100 with 2
Hello, yes you will just need a firewire 400 (6 pin) to 800 (9 pin) cable as the new iMac no longer supports the 6 pin connector.
6/27/2009 6:57:54 PM • Umax PowerLook... • Answered on Jun 27, 2009
How to clean underside of glass of a Umax
Normally you should not have to do that. If you do you have to take the glass off.
8/28/2013 2:53:56 AM • Umax PowerLook... • Answered on Aug 28, 2013
2answers
Umax mirage II not working, not recognized on xp
Hi. I have a Mirage II A3 scanner that was working fine till I save it in a closet a few years ago. Now I need it again, but I don´t have the PC I used to have with ISA port... I finally found a brand new PCI card I had in another Umax scanner, so I connected it to the PCI slot in my actual PC. And I cannot connect the scanner... I installed the software correctly, but in Test mode, it gives me a Link failure. Besides, the scanner does its setup when powered on, the lamp goes from right to left, stays there a few seconds and return to its original position. But the UTA and READY lamps keep blinking... I found this page:https://ask.adaptec.com/app/answers/detail/a_id/1869/~/scanner-test-link-failures-with-umax-scanner, that explains this can be fixed upgrading the software, but the link does no longer exist... Could you please send me the software I need to connect it..? It´s really important I can do this. I have a huge job to do but it doesn´t work... I´l be waiting for your answer. THANKS!!
8/9/2019 2:48:53 AM • Umax Office... • Answered on Aug 09, 2019
UMAX PowerLook 2100xl scanner termination
Only one termination should be powered in a SCSI chain. Generally, it should be the last device. It's been a long time since I've worked with SCSI, but I recall that scanners may be picky about where in a chain of multiple devices they are located; electrical noise on the SCSI data lines causes problems with the scanner electronics. I don't recall whether best results are found from locating it as the first device in line from the computer or the last device.
8/25/2018 11:37:24 PM • Umax Office... • Answered on Aug 25, 2018
3answers
I need umax Astra 5800 Scanner Driver and Software
i lost my scanner dirver
4/3/2018 2:57:13 AM • Umax Office... • Answered on Apr 03, 2018
Umax PowerLook 1100 Flatbed Scanner Logo
17 questions posted
Top Umax Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you an Umax Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
PowerLook Umax
  • PowerLook Umax
Most Popular Question
ihave umax power look 1100 2
  • Office Equipment & Supplies
