20 Most Recent
Nokia C1 Cell Phone Questions & Answers
Keypad
It is difficult to unlock if you forgot the code. But you can do this with data cable.But you need to have recovery software which will update recovery of your operating system.
I cannot send text my cellphone c1 Nokia?
go to msg settings text settings check the service center number ...it vary for different network provider if you dont know the correct service center number then google it or check on the same network provider on any friends phone then put the same service center number on your phone it will resolve the problem.
Site that i should open my mms
You'll need to complete all steps for this to work. Make sure that if you have to enter
O2 in the settings you use the letter
O and not a
zero.The phone has a four-way directional
Navi key and
two soft keys on either side of this. The
Navi key can also be pressed in to select options.
- Press Menu (press Navi key)
- Highlight Settings and Select (press Navi key)
- Highlight Configuration and Select (press Navi key)
- Highlight Personal configuartion settings and Select (press Navi key)
- Press Add new(press Navi key)
- Highlight Multiedia msg. and Select (press Navi key)
- Highlight Account Name and Select(press Navi key), enter giffgaff - MMS then OK (press Navi Key).
- Highlight Server address and Select (press Navi key), enter http://mmsc.mediamessaging.co.uk:8002 and OK (press Navi key).
- Highlight Use preferred access point and Select (press Navi key), highlight No and Select (press Navi key)
- Highlight Access point settings and Select (press Navi key)
- Highlight Proxy and Select (press Navi key), highlight Enable and Select (press Navi key)
- Highlight Proxy address and Select (press Navi key), enter 193.113.200.195 and OK (press Navi key)
- Highlight Proxy port and Select (press Navi key), enter 8080 and OK (press Navi key)
- Highlight Bearer settings and Select (press Navi key)
- Highlight Packet data access point and Select(press Navi key), enter giffgaff.com and OK (press Navi key)
- Skip past Network type this should be set to IPv4
- Skip past Authentication type, this should be set as Normal
- Highlight Username and Select (press Navi key), enter giffgaff and OK (press Navi key)
- Highlight Password and Select (press Navi key), enter password then OK (press Navi key), verify password and again select OK (press Navi key)
- Press Back (right soft key) six times
- Highlight Messaging and Select (press Navi key)
- Highlight More and Select (press Navi key)
- Highlight Message settings and Select (press Navi key)
- Highlight Multimedia msgs. and Select (press Navi key)
- Highlight Configuration and Select (press Navi key), highlight Personal config. and Select (press Navi key)
- Highlight Account and Select (press Navi key)
- Highlight giffgaff - MMS and Select (press Navi key)
- Press the right soft key five times to get back to the standby screen
Please switch your handset off and back on again before using these settings.The settings are now complete.hope that helps
No network
Hi this problem could happen when:1-your antenna is not attached correctly because your phone crashed or dropped2- Your antenna switch IC has problem (because dropped or dust or COLD SOLDERING)3-your matching circuit after the antenna(1 inductance 1 capacitor) cutting off 4- your PA (power amplifier) IC has problem5-your RF circuit totally is gonetake your cell phone to a certified nokia shop to repair itkind regard
Please i need to unlock my nokia c1 phone
ur defalt phones codes is 12345 or 00000 u can use it Default 4 Digit user code: 1234 or 0000Default 6 Digit Security code: 123456 or 000000Type *#06# at the mobile screen to know IMEI no of your mobile.send the IMEI no to me and i will reply you with unlocking code.IF Problem not Solved SoPlease New Software install in the Phone Problem will SolvedIf For puk & pin cod problem So PleaseVery Best Solution:You Go To Service & Sim Office and Get The Puk code And Pin code From Office opratorEnter The Puk code and YesEnter The pin code and YesSo Puk code Open and Problem will Quickly Solved
I forgot my security code of nokia c1 how to reset the code
You may try default phone and security code to remove restrictions.ur defalt phones codes is 12345 or 00000 u can use it Default 4 Digit user code: 1234 or 0000Default 6 Digit Security code: 123456 or 000000Type *#06# at the mobile screen to know IMEI no of your mobile.send the IMEI no to me and i will reply you with unlocking code.IF Problem not Solved SoPlease New Software install in the Phone Problem will Solved
