20 Most Recent Coby Kyros 7" Touchscreen Tablet Questions & Answers
How can I download netflix app on my coby kyros
http://downloads.tomsguide.com/Netflix,0301-39879.html assuming it is an android tablet . Iphone will use an apple store app
5/29/2015 1:11:49 AM • Coby Kyros 7"... • Answered on May 29, 2015
Download manual
Hope this is your model: http://www.manualslib.com/manual/254203/Coby-Kyros-Mid7015-4g.html
5/19/2015 7:40:54 PM • Coby Kyros 7"... • Answered on May 19, 2015
My coby kyros power button is stuck how can i fix it
Try opening the kyros on the babk might be hard but woth it text me back tell a perent or someone to open it you might do damage
10/20/2014 11:37:17 PM • Coby Kyros 7"... • Answered on Oct 20, 2014
Tablet won' come on. reset won't work.
So it wont do anything else you need to let the battery die chage it then ask me if it works ok
9/28/2014 8:40:51 PM • Coby Kyros 7"... • Answered on Sep 28, 2014
2answers
The charger broke off of my coby kyros tablet
You'll have to send it back plus $15.00 for shipping & handling,the company is something to deal with. My tablet still has not been replaced and I sent it back Dec.3 2012,they've received it too!! They are a mess!!
9/14/2014 7:22:28 PM • Coby Kyros 7"... • Answered on Sep 14, 2014
My Coby Kyros mid 7048 is frozen on android? How do you fix that problem?
Steps on how to do the restart. -You have to turn off the system. -Then press and hold the power button until you will see a message that will popup in a window that saying "Device Options"Appears on the screen. -Then select the power off again then you can see it again.You can be able to check that it first. -Then just select okay And while holding down the -Back -Button -Then Press and hold the power button. -Until you see the Coby`s Logo -Then wait until it change to Android Logo. - Then press the Back button.And Then the system menu will appear in the screen. -And then choose the wipe data/factory reset. >Home >Menu Buttons >Press the back,the button once you select the wipe data/factory reset then just click option. Then the confirmation that you will see in the screen Is a "yes" "Option". Then Choose "yes"-delete all user data,option by using the "Home"and "Menu"buttons. Then it will perform the factory data reset. -wait until it done. -Then once your done the main system menu has to appear in the screen. -And then reboot the system. -Then you have to press the back button to reboot the system. -The system will reboot the initial factory data setting. -All the user data will be lost. -Then Give the reboot,at least for 5 minutes. -Then Do not assume the unit has frozen.
9/8/2014 9:05:39 AM • Coby Kyros 7"... • Answered on Sep 08, 2014
Touch screen calibration utility
Try using another app for touch screen calibration.
7/28/2014 4:21:40 PM • Coby Kyros 7"... • Answered on Jul 28, 2014
Help
Most Tablets gets reset with this procedure. If it is not self recovering after powerdown, you have to reset to factory settings (meas you will losse your apps) to do do this most tablets gets reseted by presing both (Up-Down) volume keys before pressing the power on button. A text menu will appear asking you the action, you have to choose Factory Settings. Your Tablet must be poer off before to perform the avobe procedure. Hope it helps... If not volume keys works try other tablet keys. but always press keys convinations before the power on key.
5/24/2014 9:38:20 PM • Coby Kyros 7"... • Answered on May 24, 2014
How do I get my tablet to turn on?
Its Battery fault or Software problem. Check out mobile store nearby
5/22/2014 5:07:00 AM • Coby Kyros 7"... • Answered on May 22, 2014
I made a really hard password for my tablet and I can't get in.
Hi Elena, you can use the following procedure to hard reset your tablet. Turn off the tablet. Hold the back button and power button. This will take you into the recovery menu, use the volume keys to go through the menus. Select wipe data/factory reset and press the back button. I hope this helps.
4/10/2014 6:06:10 AM • Coby Kyros 7"... • Answered on Apr 10, 2014
I need to reset my tablet
Hi Elena, you can follow this procedure to reset your tablet. Turn off the tablet. Hold the back button and power button. This will take you into the recovery menu, use the volume keys to go through the menus. Select wipe data/factory reset and press the back button. I hope this helps.
4/10/2014 6:05:02 AM • Coby Kyros 7"... • Answered on Apr 10, 2014
0answers
What will id o if the browser storage is now full
clear catche
12/1/2013 1:35:53 AM • Coby Kyros 7"... • Answered on Dec 01, 2013
It will not turn on or connect to the internet
Hold down the power button for about 20 seconds, this should hard reset the phone/tablet.
11/19/2013 12:32:49 AM • Coby Kyros 7"... • Answered on Nov 19, 2013
Will not cut on
no it will not turn on or coneect when it did turn on
11/18/2013 4:23:16 AM • Coby Kyros 7"... • Answered on Nov 18, 2013
Coby Kyros 7" Touchscreen Tablet Logo
Popular Tags
85 questions posted
Top Coby Tablets & eReaders Experts
ZJ Limited
ZJ Limited
ADMIN Andrew
ADMIN Andrew
Kolbrun...
Are you a Coby Tablet and eReader Expert? Answer questions, earn points and help others
View Most Popular
kyros Coby
  • kyros Coby
Most Popular Question
need reset tablet
  • Tablets & eReaders
