20 Most Recent Brother MFC7360N AllInOne Laser Printer Questions & Answers
Why a 'no paper' error when it is full of paper?
Usualy that is happened when you try to print another format , to solve that put some paper in the manualy tray. When you receive a mail from another contry in another format : ex A4 , and your printer is set to letter , brother says no paper because the machine want to print in that format of paper. Pay attention to the setings in printer driver in computer.
7/31/2021 9:55:14 AM • Brother MFC7360N... • Answered on Jul 31, 2021
2answers
Paper Jam when paper loads into machine from paper tray about 2 inches in when printing. Then it tells me there is no paper, load more paper? All the while I am hearing a sort of screaching sound wh
It probably needs to be cleaned. There may be bits of paper stuck in the mechanism. In addition, if the printer is old or has been used a lot, the rubber on the feed rollers may need to be cleaned and roughed up a little bit to grab the paper more firmly when feeding it through. Also, when you load paper, don't load too much, and flip the sheets in the ream before you insert the paper to allow air to get between the sheets, making it easier to feed a page.
11/19/2017 11:04:56 PM • Brother MFC7360N... • Answered on Nov 19, 2017
Brother MFC 7360n I get a error NO paper
Paper tray is empty ?
1/5/2016 11:13:30 PM • Brother MFC7360N... • Answered on Jan 05, 2016
How to use memory to send fax from brother mfc7360
Call brother tech support they can help you 800-432-3532
2/15/2015 9:11:44 PM • Brother MFC7360N... • Answered on Feb 15, 2015
2answers
How can I replace scanner glass on a brother printer?
Is it broken ?
7/10/2014 4:59:38 PM • Brother MFC7360N... • Answered on Jul 10, 2014
Deep sleep on printer
I am a Brother employee working for the software technical support department. We have a solution for your printing issue posted on our solution site. http://www.brother-usa.com/FAQs/Solution.aspx?FAQID=200000032479 Description of Problem 100000025364 How do I perform a firmware update or firmware upgrade on my Brother machine? Brother Software Technical Support http://www.brother-usa.com
6/30/2014 6:45:12 PM • Brother MFC7360N... • Answered on Jun 30, 2014
2answers
Toner life counter that needs to be reset
Open the front cover, press Clear/Back, Press * 1 2, wait for message to 'Close Cover', close cover.
6/24/2014 5:17:05 PM • Brother MFC7360N... • Answered on Jun 24, 2014
3answers
Do the tone cartridge time out?
Hi, if the above suggestions dont help it may be out of toner. according to your dates and numbers. average 17.5 copies per day. you purchased it approx..300 days ago. = 5,250 total copies !?
6/8/2014 3:09:16 PM • Brother MFC7360N... • Answered on Jun 08, 2014
Will not recoginze the toner cartirdge
Hello,Open doorpress Clear/Back keypress *00press OKDo not choose anything for drum replacement. when drum replacement menu comes up, just press the * and then 00, then just press OK.
6/2/2014 7:32:55 PM • Brother MFC7360N... • Answered on Jun 02, 2014
Document jam how to make brother 7360n
Go To Below official Brother Printer Page For Your problem, Clear the paper jam or printer jam Brother Still having Problem Then follow Us For Brother Printer Support
2/24/2014 8:31:33 PM • Brother MFC7360N... • Answered on Feb 24, 2014
2answers
Clear the toner low message on my brother 7360n
I opened the cover door, pressed the clear button, but entering *00 didn't work for me but entering *12 did.
1/28/2014 4:42:58 PM • Brother MFC7360N... • Answered on Jan 28, 2014
Brother MFC7360N AllInOne Laser Printer Logo
90 questions posted
Norman Weimar
Norman Weimar
k24674
View Most Popular
MFC Brother
  • MFC Brother
Most Popular Question
clear toner low message brother 7360n
  • Office Equipment & Supplies
