20 Most Recent
Ricoh SP C430DN Laser Printer Questions & Answers
Ricoh 430dn error sc565
Pressure roller fusing lamp consecutive full power 3
When the fusing unit is not running in the ready condition, the pressure
roller fusing lamp keeps ON full power for 30 seconds or more.
?? Broken pressure roller thermostat
?? Broken pressure roller fusing lamp
1. Replace the pressure roller fusing lamp.
2. Replace the pressure roller thermostat.
3. Replace the PSU.
"set the toner cartridge correctly"
Possible the chip that reads the toner bottles shorted out.
Try new bottles. If that don't work, the board in the machine that reads them need replacing.
You will need a technician to replace them.
Disable color management
1. Find what you want to print and push print.
2. On the Print page, go to "printer options"
3. Choose to "Black Ink" in the options.
4. This might have to be done every time you print to ensure the colors are not being used every time you print.
Hope this helps----
Function Error
Best case firmware upgrade, worst case bad board. -Carl
I want to print mirror image for heat press
If you need a quick fix for printing a mirror image on your printer, download and install CutePDFwriter
http://www.cutepdf.com/products/cutepdf/writer.asp into your printers. This is a free download. Choose the printer preferences.Click the "Advanced" button. Click on the + sign next to "PostScript Options". Change the Mirrored Outpout: from No to Yes. This will let you print to a PDF file without messing up your original document. You can then print the PDF file to your paper. This may not fix your printer but it is a quick fix to do what ever and then you don't have to make the changes again if you want to print the item, picture, text, etc. again. Hope I have helped.
TURN OFF COLOR PRINTING
Go to your printer properties, tick the GRAYSCALE Printing or find the option where you can choose the BLACK ink to print only.
