20 Most Recent
Toshiba Notebooks Canvio E05a075cau3xw 750 Gb External Black Usb 30 5400 Rpm Hard Drive Questions & Answers
My toshiba external harddrive usb 3.0 won't work
click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red xright click to reinstall drivers or if you can see your usb but its not workingports(com&lpt)right click update driver sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable,just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again,
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems also make sure the computers Ram and Cmos battery are securely seatedif this fails to fix the problem hope this helps you
9/10/2014 7:17:00 PM •
Toshiba...
Answered
on Sep 10, 2014
Windows will not start with a Toshiba external hard drive plugged into USB
Computer starts normally in windows with a windows that is installed on a hard disk on that copmuter. In other words - windows is installed on an internal hard disk of a computer A. If you get it out and put in a computer B it wont work.
To have the things work:
1. First should set in BIOS boot up options first boot device CD/DVD, second OTHER/USB/EXTERNAL, third HDD
2. Should boot up from a CD and install windows on an external hard disk (in your case your 3TB Toshiba external HD)
3. Set in BIOS boot up options first boot device OTHER/USB/EXTERNAL, second internal hard disk e.g. HDD0, HDD1
How to transfer 500GB from one hard drive to another
The "drive not ready" error can have several causes.
Commonly, ownership or access permissions have not been set up properly for the files, the folders, or the entire disk, and this can be reported erroneously as a "not ready" state. VLC would have nothing to do with this, unless it was during its installation that the permissions accidentally got whacked.
You didn't say which file systems are involved, and that can make a difference.
There is always the possibility that the drive and the computer really cannot communicate with each other. If you are lucky, it is just a bad cable, otherwise it is the controller or the drive itself that actually is at fault.
Lost login info, what should we do?
You are talking about accessing a Hard Drive via IP Network Address. Very difficult to troubleshoot via this method as the Network protocol interfears. Try plugging the drive in via USB or FireWire etc.
On A hardwired port it is easier to access the drive & copy it's contents to a backup device before formatting & testing the drive and adjusting the IP address to you preferred settings.
The drive can also (probably) be taken out of it's case box and plugged into another case with a USB port on the back or directly into it's ATA or SATA port on the actual drive. This is the preferred way to back up as it's much faster than Network or USB access for large file transfers. You can buy external empty cases. eg. See OWC. Other World Computing website.
Toshiba Canvio 1 TB connection problem - physical layer issue may be on cable or on HDD mini-USB port itself
More than likely, this is some sort of fault in the logic of the external enclosure. The solid light indicates that the drive is powered and is awaiting access while the blinking light means that it is busy working. If you are unable to get the drive to do anything (whether reading data from the drive or storing data to the drive), then I would guess that it is time to see whether you still have warranty coverage on the drive and, if so, get it replaced under warranty.
In my experience, I have found that Toshiba drives are very unreliable and therefore would recommend that you replace it with a Seagate if this drive no longer has any warranty coverage. Of all the drive manufacturers, I have found Seagate drives to be the most stable and reliable. Others may recommend Western Digital but I replace failed Western Digital drives on a constant basis in my computer repair business each and every week while Seagates keep on going. I base my recommendation on being in business now for over 25 years.
3 tbs
Does not need a driver.
COMPATIBILITY:
- Formatted NTFS for Windows XP, Windows Vista, Windows 7 or Windows 8
- Requires reformatting for Mac OS X Tiger, Leopard, Snow Leopard or Lion
- Available USB 3.0 or USB 2.0 port
- USB 3.0 port required for high speed transfers
I cannot drag files in the Toshiba Canvio Basics 2,0 TB
Please test it by cutting a data file and pasting it in this hard drive. If it is success, then probably the type of your data is different and it is not freely moveable, or you it is possible that you tried to move the files to the same folder (it happens when the user opens many Windows Explorer/File Manager).
How do I click & drag
with the help of first mouse button you should click , then keep it on, on the click position then release the button where you want to drag it
Toshiba washing machine model AW-DK1700WMM has turn on, beeps with error code EL then shut down within 5 seconds, how can I slove this problem?
To fix the EL error code:
* Make sure the door is completely closed and latched securely. A loose or broken latch can cause the error.
*Examine the door lock for any damage, dirt, or debris that could prevent it from working properly. Clean the area thoroughly.
* Turn off the washing machine, then unplug it for a few minutes. Plug it back in and restart it. This may resolve communication issues that trigger the error.
* Examine the wiring connections between the door lock system and the control panel. Faulty connections, such as loose or damaged wires, can disrupt communication and lead to the error message.
3/26/2024 1:48:19 PM •
Toshiba...
Answered
2 days ago
How to fix tablet toshiba wt8-a
Ensure the cd rom is empty and the bios is set to boot from drive C first, then drive D.
If all in order and it still doesn't boot, try a system disc in the cd rom.
10/11/2023 4:56:30 PM •
Toshiba...
Answered
on Oct 11, 2023
