20 Most Recent Hitachi Touro Desk 1 TB USB 20 External 0S03288 Black [Amazon FrustrationFree Packagi Hard Drive Questions & Answers
I need a new circuit board for 1.0TB Hitachi external hard drive. Does anyone know where I can get a replacement
The cheapest way will be to buy the same drive again. Spare parts are very scarce and for that reason very expensive. When you want yo save the data on your drive, and you think the board is defect, think this will be the cheapest option.
2/4/2015 11:08:32 AM • Hitachi Touro... • Answered on Feb 04, 2015
How do i format it for xbox 360
You can use a USB flash drive as an Xbox 360 storage device and store up to 32 gigabytes (GB) of content.
11/9/2014 8:29:02 PM • Hitachi Touro... • Answered on Nov 09, 2014
Touro 1tb is lite up, but this isnt showing on my computer, it was working perfectly fine yesterday and now it doesnt, I have tried a different USB cable and this hasnt worked, please advise?
Hello Stellafox, The issue you describe is generally a simple hardware failure but without further diagnostics it would be impossible to advise you as to where the failure resides. If you are technically capable, follow the directions below, if you even have to consider how capable you are, take it to a repair shop and ask them to try these steps. First, connect the device to a different computer, listen carefully for clicking scratching or ticking sounds, if you hear any report back including your country and state/province and I can recommend a nearby recovery facility. If not proceed to check within computer management(Windows) or in disk utility(Mac) to see if the device is registered. If not remove it from it's enclosure (voiding any warranty) and repeat this step. If the device does not show up on Disk Management on two or more devices, striped of it's enclosure, again refer back and I will recommend a data recovery facility near you. If it shows up at either stage, the problem is most likely logical in nature, check the size of the drive and ensure it roughly matches the stated size(won't be exact). If it does but the partitions show up as RAW or UNALLOCATED, advise and I can recommend a software solution for recovering your files, if it does not show up or shows up in a place like Device Manager but either does not show up or shows up as 0GB and or Uninitialized but refuses to initialize, again hardware failure we can connect you with a pro. If you are looking at a software solution, ensure the computer you are connected to has sufficient space to recover all of you files or purchase and connect a new drive of appropriate size before proceeding. We can recommend software for this purpose or if you'd prefer a company who can dial in remotely and assist you with the recovery process. Of note if you got to the step where the drive is removed from the case and it not only showed up but also has access to your files, back them up to a second device then purchase a USB/eSATA enclosure to put the drive into as the failure was in the enclosure and not the drive. If none of these steps work or you get very different results, report back, be specific and include all the details you can think of and we will help you assess your next diagnostic step. Hope this helps, Chris
10/13/2014 5:10:05 AM • Hitachi Touro... • Answered on Oct 13, 2014
Hitachi 1 TB external hard drive won't power up
yes you can fixed it replase cover and and cut hdd and buy new rak out side and conected the new rak with hdd that is very esy
4/26/2013 12:12:48 AM • Hitachi Touro... • Answered on Apr 26, 2013
Wont read anymore or do anything!
large hard drives dont like being swapped around to different computers and there operating systems they are not good swingers
try connecting the drive directly to a port on the computer.
click start control panel administrative tools computer management device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X
you will need to update/reinstall drivers
right click to reinstall drivers
if you can see your usb but its not working
ports(com&lpt)right click update driver
Also check if it's detected in "Disk Management".
Here you can verify if the partition and format are correct for the Operating System.
Check the Drive's status in Device manager.
This will verify if the external drive has a drive letter designation.
Check Partition and Format.
Log in as Administrator account in windows or any other account with administrative privileges
Insert your removable disk into the USB port.
Click Start, right click on computer and select manage.
Now, click Disk Management.
Check whether drive letter for the device is present.
Check the lower window to find whether the device is detected (such as Disk 1, Disk 2, etc).
If the device is detected with a drive letter, verify that no other device is using that drive letter.
If it is, change it to unused drive letter.
hope this helps
9/20/2012 9:23:48 PM • Hitachi Touro... • Answered on Sep 20, 2012
0answers
YOU NEED TO FORMAT THE DISK
I think you need to format disc.
3/31/2014 9:22:41 PM • Hitachi Touro... • Answered on Mar 31, 2014
0answers
0answers
Hitachi 50hyt62u H can I add a removable drive as I have a slot in Back for one, and if so where do I get one
You should be able to buy an external USB drive (or thumb drive) at any electronics store. You can connect a USB hard disk drive or USB memory stick to your TV by using the USB inputs of the TV. This feature allows you to play files stored in a USB drive. 2.5" and 3.5" inch (hdd with external power supply) external hard disk drives are supported. IMPORTANT! You should back up your files before making any connections to the TV set in order to avoid any possible data loss. Manufacturer will not be responsible for any file damage or data loss. It is possible that certain types of USB devices (e.g. MP3 Players) or USB hard disk drives/memory sticks may not be compatible with this TV. Quickly plugging and unplugging USB devices, is a very hazardous operation. Do not repeatedly quickly plug and unplug the drive. This may cause physical damage to the USB player and USB device itself. Do not pull out USB module while playing a file. Media Browser Menu You can play photo, music, and movie files stored on a USB disk by connecting it to your TV and using the Media Browser screen. To do this, perform the following: Connect a USB disk to one of the USB inputs located on the side of the TV. You can connect two USB devices to your TV. If both USB devices include music, picture or video files, USB selection OSD will be displayed on the screen. The first USB device connected to the TV will be named as USB Drive1. Select a device by using up or down arrows and press OK
11/30/2019 1:10:18 PM • Hitachi... • Answered on Nov 30, 2019
How to connect my Mac book pro to a Hitachi projector
You will have to use the HDMI port on the mac. provided you have a HDMI input in the projector
11/26/2019 12:41:17 AM • Hitachi... • Answered on Nov 26, 2019
HiTaChI pRinTeR inStaLlAtIoN cuStOmEr sErViCe nUmBeR $1.{877}*{76.9}*{09.69}*#$ 24/7
BENJAMIN, Your message does not qualify as a question or query for a problem, try somewhere else DO NOT MAKE THIS SITE WITH YOUR GARBAGE Take your GARBAGE to another Side Your message qualifies as SPAM
11/7/2019 5:39:59 AM • Hitachi... • Answered on Nov 07, 2019
My Hitachi XL500 external hard drive is not showing anywhere on my computer. I also do not believe any power is getting through to my hard drive. Please help
buried in endless spam are you. does it fail on 2nd PC???????????????????????????? but yes, I am the MVP of external HDD< I build my own. Have over 5 here for Backups . lots of causes, for sure bad drive, or missing drivers.. bad HW hardware or BAD software SW. Missing 12vdc 2amp power pack>, lost or using wrong one. when pack above does the HDD spin? usb connected to PC. NO PC stated, NO OS stated, windows/chrome/Linux/android? its at lease 10 years old , see posts back that far. not good old HDD,this old. sold during W7 era. 2009. The drive has 3.5" HDD that needs lots of power (Amps) to start up that big motor inside, and is first thing to learn . 2amps it needs, ok? so if pack is missing it will never startup on any USB port, not rated for 20x standard USB load factors. some laptops only do 0.1amps (100mA) and are useless to startup any hdd motor of any kind. see why here. and see a better extremal solution cheap.! $10 http://www.pcdied.com/external-hdd.html
7/3/2019 1:28:14 PM • Hitachi... • Answered on Jul 03, 2019
Hitachi Touro Desk 1 TB USB 20 External 0S03288 Black [Amazon FrustrationFree Packagi Hard Drive Logo
Popular Tags
7 questions posted
Top Hitachi Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
ADMIN Andrew
ADMIN Andrew
vince
Are you a Hitachi Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
Touro Hitachi
  • Touro Hitachi
Most Popular Question
need new circuit board 1 0tb hitachi
  • Computers & Internet
