20 Most Recent
Kodak EasyShare LS753 Digital Camera Questions & Answers
How do I fix error
Error # 45 means the retractable lens is stuck, possibly caused by a drop or sand or other gunk that has jammed the gears. It will cost more to have repaired than the camera is worth, so you have nothing to loose by trying this. Hold the camera in your strong hand with the lens away from you and smack it hard into the palm of your other hand (if you can't take pain maybe use the heel of a shoe) pretty hard. It may take several tries. Best results - smack camera immediatly after turning off.
What does error # E45 mean? I can't find my
Hello
Thank you for using FIXYA!!!
This
is a suggestion. If you do not feel comfortable trying it, you will need to take
the unit to your nearest service centre. Feel free to let me know if you
need any assistance.
The problem might be that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the
probability is that you will have to get it fixed by a professional.
Use
these at own risk as it may further damage the camera.
Firstly ,
try connecting your ac adapter or usb cable.
Try holding the
shutter button while switching on the camera.
Look at the lens ,
and if some of the lens 'circles' is misaligned or not concentric then
try wiggling it (while holding camera lens down).
Try gently
pushing or pulling the lens when it extends but this is risky as it may
cause the lens barrel to slip out of its guidance system.
Another
way to do this is to place the camera lens down on a hard surface and
then power it up. Be sure to use a soft cloth or something similar as to
not scratch your lens or casing. Let the lens push the camera up and
down a few times and sometimes the little resistance provided by the
camera is enough to get things going again.
Try hitting your
camera near the lens on the body with the soft tissue on the palm of
your hand.
Other than that , I would take the camera to a repair centre for a evaluation to see if it would cost more to repair than to
replace the camera.
If it is still under warranty I would suggest
you take it in before trying any of these steps and remove any
off-brand batteries or accessories as some stores are really fussy about
warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope
the advise is useful. please do not hesitate to let me know if you need
any further assistance. Also, please be so kind to let me know if you
found this helpful.
Regards
Andrea
E 45 Error: ,the lens
Hello
This
Use
Firstly ,
Try holding the
Look at the lens ,
Try gently
Another
Try hitting your
your hand.
replace the camera.
Hope
found this helpful.
Regards
Andrea
Errore E45
Hello
This
Use
Firstly ,
Try holding the
Look at the lens ,
Try gently
Another
Try hitting your
your hand.
replace the camera.
Hope
found this helpful.
Regards
Andrea
Kodak EasyShareLS753 screen has camera
Hello and Welcome to FixYa!
E45 error message sometimes means that the lens is misaligned, This error is also may be due to failure of the control system.
To solve this follow the given solution:
You can remove
battery and card replace battery and while switching on tap the lens
hood on your hands so as to disengage any dirt or mechanism being
struck.
Use some air to blow between the lens to dislodge any sand
particles struck inside. If none of these works then you can think of
taking consensus with the service center. You must keep in mind that to open the camera without good experience is not recommended and might tamper the delicate unit so best option is to Contact
Kodak to see if your camera is still under warranty, otherwise contact
any Kodak Cameras service provider, your problem will be solved.
I hope this solution helps you
Don't hesitate to let me know if you want any further assistance.
Thank you for using FixYa!
Error code E45 when powering
Try tapping the side of lens, or smacking the camera gently on the palm of your hand when it's on, then restart the camera.
It could be a problem with the lens mechanism, and the gentle, yet firm tapping may help.
I have easy share kodak digi camera it shows error
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the
Use
Firstly ,
Try holding the
Look at the lens ,
Try gently
Another
Try hitting your
your hand.
replace the camera.
Hope
found this helpful.
Regards
Andrea
I turn on my Kodak
Hello
Use
Firstly ,
Try holding the
Look at the lens ,
Try gently
Another
Try hitting your
your hand.
replace the camera.
Hope
found this helpful.
Regards
Andrea
When I on the camera
Hello
Use
Firstly ,
Try holding the
Look at the lens ,
Try gently
Another
Try hitting your
your hand.
replace the camera.
Hope
found this helpful.
Regards
Andrea
I have a camera and
Hello
Use
Firstly ,
Try holding the
Look at the lens ,
Try gently
Another
Try hitting your
your hand.
replace the camera.
Hope
found this helpful.
Regards
Andrea
