20 Most Recent
Kodak EasyShare DX7630 Digital Camera Questions & Answers
Can't sync iphone to computer. Error (13019) occurred.
There are various reasons for this issue like below shows.
The problems to cause "Can't sync iphone to computer. Error (13019) occurred" can be various. You can refer to the following aspects to check and fix this issue.
1. Maybe your iTunes version is outdated and you need to update it to the latest version to ensure it to work normally.
2. Maybe there is something wrong with the USB cord you are using. You can change a new cable to have a try.
3. Maybe your computer system needs to update. You can check out your Windows system and access to new updates to handle this issue.
4. Maybe your iPhone system version needs to be updated. You can go to "General" tab on iPhone to check for
iOS updating and follow the on-screen instructions to make it.
If you fail to settle "Can't sync iphone to computer. Error (13019) occurred" by trying the 4 methods shown above, you can continue to read the below instruction to help you to realize your goal.
Check:
How to Fix iTunes Not Recognizing iPhone in Windows 10
The viewfinder is blank and
Its a camera CCD Problem. If the View finder & LCD both showing black then its 100% CCD problem. Let me know Lcd also black? Also make sure lens is not covered by any thing.
"High camera temperature"
this worked for me: just hit the bottom hard with your palm and the top and sides, not the front or back. After 3 hits, the date screen came back on and it was fixed. This was after the other two solutions I found on this site failed, namely pushing the shutter down before the message comes on or blowing into the camera slot with the memory card removed.
Kodak Easyshare DX7630 Can't Tranfer Pictures
Consider NOT connecting your camera to your computer.The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as
Picasa or Kodak's.
Flash doesn`t work
hi try to reset ur camera...To do such reset, turn on the camera and hold the menu button down for longer than 5 seconds. A message should hopefully come up on your LCD asking if you want to reset the camera. Select Yes...thank u!!!
rate me!!
Dx7630 kodak easyshare
the 5-way switch breaks it's solder connections on several Kodak models. if you have a soldering iron with a fine tip and are comfortable working on small soldering joints it is possible to repair the joystick (there are 10 solder connections on a 1/4 inch square switch, 3 on two sides and 2 on the other two sides)
Will not format memory card
Your camera uses mmc/sd cards. If you are trying to use, for example, an SDHC card, the camera cannot use it and therefore will not format it.
Lcd screen does not show scene and photos are all
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so,
please see this link for further info and a simple fix that may help.
When I switch on I get the "Set date and time"
Hello.
Your first problem has something to do with your camera's "Internal Battery". It might be dead. That happens when the camera is left without a charged battery for a long period of time. According to Kodak, it "usually" corrects itself by putting in a fully charged batteries and don't use it for 24 hours. If it doesn't correct itself by then, you need to send it to them so they can service it.
About your second problem, your RIGHT button might be malfunctioning. Can you use it to change settings? Is it just not functioning when viewing pictures?
I format the memory card
Try a different card. The cards are only good for a certain number of writes, then they're done.
The LCD monitor of my
hi
your unit has shutter unit defective in lens unit assemble. you can bring to your local repair shop would charge around $45 to 95 depend on what they really want to charge.
Thanks and best regard!
