20 Most Recent Kodak EasyShare C310 Digital Camera Questions & Answers
Error e00100
Check whether it has been charged properly
12/10/2013 1:54:49 PM • Kodak EasyShare... • Answered on Dec 10, 2013
0answers
I have a Kodak DX4330. I have used it for years and suddenly it stopped taking pictures. It goes through the motions but is black. I have changed batteries, cards, cleared the card and the internal m
It could be the CMOS sensor has failed, it would require a new module but the expense of it would just warrant a new camera.
11/14/2013 8:16:54 PM • Kodak EasyShare... • Answered on Nov 14, 2013
Free software download
Do you really want the Kodak software?The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa ( http://picasa.google.com ).If you really want the Kodak software, you may download it from http://support.en.kodak.com/app/answers/list/c/890/selected/true
10/28/2013 5:44:52 PM • Kodak EasyShare... • Answered on Oct 28, 2013
Do i need to turn off my c310 camera before
Nothing bad will probably happen if you don't turn off the camera before inserting/removing the memory card. But something bad is less likely to happen if you do turn it off first.I suggest you get into the habit of turning off the camera before inserting removing the memory card.
9/27/2013 1:31:04 AM • Kodak EasyShare... • Answered on Sep 27, 2013
2answers
Kodak Easy Share C310
Since the computer makes sound, it sees your camera. The problem might be you did not go all the way with the connection processs. If you can't use the usb port with other usb devices, your usb driver might be disabled or corrupted. Check your usb driver through the device manager.
1/13/2013 6:10:51 PM • Kodak EasyShare... • Answered on Jan 13, 2013
Make be webcam
Take a look at this.
12/11/2012 7:19:00 PM • Kodak EasyShare... • Answered on Dec 11, 2012
How do you shut off flash?
Press the flash button (marked with a lightning bolt) to cycle through the flash modes. To turn off the flash, select the lightning bolt in a circle with a slash through it. For full details, see this page of the user guide.
11/13/2012 4:13:45 PM • Kodak EasyShare... • Answered on Nov 13, 2012
Error code 105-100007
The non-functioning of the camera can be a fault in the shutter, zoom or auto focus sections and may be due to the failure of the Main control system or the drive. A simple was is to reset and we can try by removing the battery and card for some time. Now replace only the battery and while switching power ON, tap the lens hood on the palm of your hands so as to disengage any dirt or mechanism being struck. You can spray a degreasing spray on the lens hood sides and also assist the lens as it tries to come out, attempt to pull it out slowly while powering ON the camera. Also in some cases you can slid a thin film/paper on the lens hood sides to wipe out any dirt.
Tips to open and check for common faults: http://www.youtube.com/watch?v=v2Mj3Qp3xYU&feature=related Use some air to blow between the lenses to dislodge any sand particles struck inside. Unless you are familiar with handling of small devices must you try and open. If so check the voltage on the motor drive check the auto focus and Zoom drives, it must be free with manual movement. If jammed the motor can be removed and released. If none of these works then you can think of taking consensus with the service centre.Get estimate before you decide. It will be good to have it checked at the authorised service as you do not have to run around for spares.
11/8/2011 4:33:21 AM • Kodak EasyShare... • Answered on Nov 08, 2011
How to format Kodak EasyShare
Press the MENU button. Use cursor-up/down to highlight the setup tab (three horizontal sliders) and press the OK button. Use cursor-up/down to select Format and press OK.
http://resources.kodak.com/support/shtml/en/manuals/urg00431/urg00431c4s6.shtml#BABHEFCC
7/26/2011 6:16:27 PM • Kodak EasyShare... • Answered on Jul 26, 2011
Why does the video of
This is one of the early kodak cameras to first incorporate video capability along with picture taking. Unfortunately, kodak did not include a microphone with design of the camera. Sorry, the camera is not capable of taking video with sound.
7/3/2011 5:59:52 AM • Kodak EasyShare... • Answered on Jul 03, 2011
Taking a close up of an item 6" long is not
According to the manual, the C310 has a fixed-focus lens with a working range of 0.85 m (about 33 inches) to infinity. So, anything only ten inches from the camera will be out of focus.
6/23/2011 8:11:17 PM • Kodak EasyShare... • Answered on Jun 23, 2011
What GB memory card does
The C310 will accept SD cards up to 2GB in size and SDHC cards up to 32 GB. 1GB SD cards are getting hard to find, but 2GB cards should work just as well.
BTW, FixYa doesn't have an online store.
6/21/2011 4:23:39 PM • Kodak EasyShare... • Answered on Jun 21, 2011
Can't get pictures off the
Having gone over two months without a response to my query, I assume my suggestion to use a card reader solved the problem.
5/5/2011 4:24:16 PM • Kodak EasyShare... • Answered on May 05, 2011
Does not download pictures on
Here is a tip that I wrote about how to find the manuals, drivers, downloads andsupport for Digital Cameras.
DigitalCamera Manuals, Drivers, Downloads, and Support How to easilydownload Pictures from Digital Camera
heatman101
4/30/2011 7:57:13 PM • Kodak EasyShare... • Answered on Apr 30, 2011
Easy share printer dock series
Here is a tip that I wrote about how to find the manuals, drivers, downloads and support for Digital Cameras.
Digital Camera Manuals, Drivers, Downloads, and Support
heatman101
4/23/2011 1:58:09 AM • Kodak EasyShare... • Answered on Apr 23, 2011
Kodak EasyShare C310 Digital Camera Logo
110 questions posted
Top Kodak Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Kodak Camera Expert? Answer questions, earn points and help others
View Most Popular
EasyShare Kodak
  • EasyShare Kodak
Most Popular Question
need turn off c310 camera before
  • Cameras
