20 Most Recent
Lowrance LMS-337CDF GPS Receiver Questions & Answers
Lowrance completely dead
my lowrance lms 337c df will not power up. I checked all the cables and poer and they are good . can you assist me
9/10/2013 11:42:04 PM •
Lowrance...
Answered
on Sep 10, 2013
My Lowrance LMS-337c df keeps going crazy.
Normal 0 false false false MicrosoftInternetExplorer4 st1:*{behavior:url(#ieooui) }
/* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}This could be caused by glitch in the operating systemsoftware or by low voltage due to a short in the unit or somewhere in the boatswiring.
To troubleshoot the problem Iwould recommend the following steps.
- Try a soft reset
- If the problem resurfaces, try a hard reset
- Update the the operating system software
Soft Reset (Does not delete GPSData) 1. Turn unit OFF 2. Press and holdthe PAGES key 3. Press and hold the PWR key 4. Release both buttons when the USA mapAppears Hard Reset (Deletes stored GPS Datasuch as Waypoints and trails)1. Back up any waypoints, routes,and trails that you want to save on a blank MMC card2. Turn unit OFF3. Press and hold the ZIN&ZOUTKeys atthe same time4. Pressand hold the PWR key5. Release both buttons when the USAmapappears To update the operating system software, check out this link:
Lowrance337c df update
If you don't have a card reader I can program an update card for you.
3/25/2013 12:10:44 AM •
Lowrance...
Answered
on Mar 25, 2013
I'm trying to download updated
Its possible that the SD card is over-sizes for your device; try to copy the software update to another 2GB SD card and and test it.
Tell us your news.
7/17/2012 6:25:32 PM •
Lowrance...
Answered
on Jul 17, 2012
Gps is not working,on the screen it says moduler
First I'd suggest you to do an UPDATE. There is a FREE SOFTWARE UPDATE called "1.9.0" and it can be taken from
here.
If this update will not help and if you ill get the same message that means your GPS module is defective and it has to be replaced.
But before of that you have to check these steps to ensure that everything is OK:
# make sure that a proper power is supplied to the unit
# check and
clean connections between the display portion of the unit and the GPS
module. There is an intermediary connection on a power cable that
the GPS module connects to. Clean all connections with an anti-corrosion
cleaner for electronics as needed.
# reset the unit
3/4/2011 11:40:03 AM •
Lowrance...
Answered
on Mar 04, 2011
Gps not working
I know this may sound funny but replace the water temperature sensor cable that's connected to the unit. There is a module in the temperature sensor cable that has been going bad on a lot of these units recently. I had the same problem and replaced the temperature sensor cable and that fixed the problem.
2/26/2010 12:25:04 AM •
Lowrance...
Answered
on Feb 26, 2010
Gps
I have a manual for this unit but i'm still using mine so not willing to sell it to you. I'm in Melbourne and you're welcome to borrow it for a week or so or i could probably photocopy/scan certain sections for you and email them if it helps. Let me know if you still need it by emailing me at
[email protected]Cheers,
Josh
9/25/2009 9:22:33 PM •
Lowrance...
Answered
on Sep 25, 2009
Lowrance LMS 337
I wonder if the module has failed again, have you tried reseting the device?
I'm looking into this but I suspect that repairs are required again.
7/9/2008 3:42:45 AM •
Lowrance...
Answered
on Jul 09, 2008
