20 Most Recent Kenmore Elite 78722 78729 Bottom Freezer French Door Refrigerator Questions & Answers
How do I fix my ice maker
Sounds like ice maker needs replacing
11/17/2017 5:42:30 PM • Kenmore Elite... • Answered on Nov 17, 2017
0answers
What does error code IF mean
Ice fan
4/3/2016 10:12:04 AM • Kenmore Elite... • Answered on Apr 03, 2016
ER CF error code on fridge
Sarah can you look in the refrigerator door or around the fresh food section door for a model number that looks like 106.78900 I need that number to be able to tell you what the error code is. Appliance 911 Sea Breeze
11/26/2015 7:38:56 AM • Kenmore Elite... • Answered on Nov 26, 2015
Top element of oven will not heat
test it with meter for ohms continuity
4/9/2015 6:59:56 PM • Kenmore Elite... • Answered on Apr 09, 2015
Where is the defrost timer on Kenmore elite refrigerator 596.73502200?
usually inside fridge at top center covered by a plastic plate
4/9/2015 5:31:05 PM • Kenmore Elite... • Answered on Apr 09, 2015
Kenmore elite bottom freezer refrigerator not
Fridge not starting? CLICKING? FIRST ALWAYSCHECK FORpower at the outlet,checkfor 120 volts. MAY HAVE A BAD START RELAY OR CAPACITOR ON THE COMPRESSOR , CAN BUY A INEXSPENSIVE 3 IN 1 HARDSTART KIT AND BY PASS THEM , NOT THAT HARD TO DO, COMES WITH INSTRUCTIONS> BY THE WAY DO U HEAR ANY CLICKING SOUNDS FROM COMPRESSOR? BUT U MAY ALSO WANT TO CHECK UR COLD CONTROL THERMOSTAT IF IT GOES BAD U MAY GET A NON START ALSO HAVE IT CHECKED FOR PROPER VOLTAGE AND OHMS RESISTANCE WHEN IN THE ON POSITION A BAD DEFROST TIMER CAN SHUT DOWN COMPRESSOR HAVE IT CHECKED WITH MULTI METER. to check the defrost timer, u can get by and test manually by placing a small screw driver into the tiny slot or hole underneath the timer and turn slowly clockwise till u hear 1 click. this will engage ur defrost cycle in about 15 minutes u should be able to come back and feel the heat in freezer as it melts the ice providing ur terminator is not bad? Another way to test it is with a multi meter. Remove timer it from fridge and you will see 4 prongs numbered 2,1,4,3 in that order. Place ur meter prong on prong 1 & 3 (if your fridge has a capacitor wired in series with the windings, then u check for micro fares rather than OHMS) If u cannot confirm this test, still try the next. Take ur meter prong and connect to prong 1 & 4, it should read resistance or ohms ( closed) now remove prongs and place on prong 1 & 2, this should now read infinity or open (no ohms) now take a small screwdriver place it in the tiny hole or slot under the timer. Turn it clockwise slowly till u hear 1 click. Now ur 1& 2 should read closed ( showing ohms or resistance) now place meter prongs on 1 & 4 and you it should now show open ( or no resistance - no ohms) this is how u know ur timer is good, Remember when testing for ohms ADJUST meter to use a high ohms rating in the thousands as the resistance is very high in OHMS. And adjusting to low ohms rating may give a false reading or not show the proper resistance.. AT TIMES YOU MAY HEAR THE COMPRESSOR CLICK OFF AND ON OVER AND OVER. Signs of a bad start relay or capacitor. Check with an OHMS meter for continuity (ohms) and voltage, capacitor can be checked for Microfares. To check ur compressor with multi meter: Disconnect and remove the relay and capacitor from compressor, somes located next to compressor in a casing. You wills see 3 prongs coming out of compressor. 1 goes to ur srtart winding, 1 goes to ur run winding and the center goes to ur ground. Place ur meter connector or prong on the start prong and the other on the ground (center prong) take note of the reading in OHMS for example 5 ohms. Next place meter prong on run prong and the center ground prong agin. Take note of the reading in OHMS. Example 4 ohms Next place meter prong on the start prong and the other on the run prong, now take note of the reading example 9 ohms. Now match the total of this ohms test with the total of ur two separate test. 9 ohms, if they match ur ok give or take 5 percent plus or minus. One more test to make to test of there is a short in compressor attach meter prong to ground prong and rub the other end of meter prong to metal ( scrape the metal clean of paint and test on metal surface not painted surface. If it shows continuity or ohms , u have a short in ur compressor. It should show infinity
4/9/2015 4:54:24 PM • Kenmore Elite... • Answered on Apr 09, 2015
Icemaker and water spout in door not working
Probable inlet water solenoid valve failure. This solenoid valve is located on the back of the unit and attached to the water supply line from your house.
2/6/2015 6:06:20 PM • Kenmore Elite... • Answered on Feb 06, 2015
Why is the freezer too cold and my fridge not cold at all
check for the fan below if working. or u turn ur no frost frige off, doors open for two three day to allow the formation of ice to defrost ...if persist u need a techincial to check on the general components e.g termistor, heater, soloniod e,t,c
1/27/2015 12:43:50 AM • Kenmore Elite... • Answered on Jan 27, 2015
How do i reset a kenmore elite fridge after installing a new control board?
I wouldn't think that it needs resetting?? Is the fridge not working at all now? Have a close look at the old board and the new one. Some manufacturers leave little "jumper" plugs off new boards and you have to take them off the old board and transfer them to the new one. Look very closely... They are hard to see sometimes.
1/25/2015 7:37:18 PM • Kenmore Elite... • Answered on Jan 25, 2015
2answers
Why does my refrigerator smell so bad?
PUT A BOX OF BAKING SODA IN REFRIGE AND 1 INTO FREEZER ALSO. BUT TAKE EVERYTHING OUT, MAKE SURE NOTHING SPILLED AND IS UNDER A DRAW ROTTING. IF ALL IS CLEAN INSIDE, PULL OUT REFRIDGE IN BOTTOM BACK IS AN EVAPORATOR PAN FOR CONDENSATION, SOMETIMES SOMETHING CRAWLS UP INSIDE GETS TRAPPED AND DIES. YUCKY BUT VERY REAL
1/5/2015 2:20:43 PM • Kenmore Elite... • Answered on Jan 05, 2015
Why is there frost and ice in my freezer
If this is a frost free unit they actually have an internal heater. If you block the outlet for the cooling air in the freezer the heater cannot sense the dew point temp so it will not activate. Ice accumulates at the dew point temperature. Make sure the outlet isn't blocked. My wife blocks it all the time despite my many warnings not to. It's easier for me to rearrange things than keep repeating myself.
8/23/2014 7:01:04 PM • Kenmore Elite... • Answered on Aug 23, 2014
Refrigator does not stop running
thermal switch is faulty.replace it
6/29/2014 5:57:02 PM • Kenmore Elite... • Answered on Jun 29, 2014
0answers
Managemylife
You must start with a model number. I am here should you need me, Thanks John Tripp Appliance 911 bce41811-fce3-4c43-b18f-ef512e0088b3.jpg fdea2a0d-776a-4371-8e5e-d8d72dcb4ff7.jpg
4/24/2014 3:28:49 AM • Kenmore Elite... • Answered on Apr 24, 2014
Kenmore Elite 78722 78729 Bottom Freezer French Door Refrigerator Logo
85 questions posted
Top Kenmore Refrigerators Experts
vince
Johnny 1000
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
  • Kenmore Refrigerators
Most Popular Question
error code mean
  • Refrigerators
