20 Most Recent Intel Play QX3 Monocular Microscope Questions & Answers
Intel play microscope installer says directx 8 not installed
Have you tried here? https://download.cnet.com/intel-play-qx3-microscope/3000-2110_4-104288.html
1/3/2024 7:33:30 AM • Intel Play QX3... • Answered on Jan 03, 2024
5answers
Need drivers for intel play qx3 for windows 7
Sure, they can be downloaded easily by using this software: Driver Update Software for XP Vista 7 8. Wish you best of luck. Cheers
6/12/2019 10:53:05 PM • Intel Play QX3... • Answered on Jun 12, 2019
2answers
Need qx3 drivers for windows 7 64 bit
The Intel QX3 is not compatible with 64 bit operating systems. It will not work. Sorry.
You can either reinstall Windows 7 as a 32-bit version or purchase a QX5 model which is compatible with Windows 7 64-bit.
-Mark
3/17/2018 11:07:54 AM • Intel Play QX3... • Answered on Mar 17, 2018
I need dowland drivers to intel play model APB 24221 99A
Here are the instruction for installing the QX3 (or QX3+) Microscope with Vista and Windows 7. You must be using a 32-BIT VERSION. The QX3 is not compatible with 64-bit versions. Note, DO NOT use the software from the CD that came with the microscope. DO NOT plug in the QX3 microscope until Step 4. Step 1. Download and install the QX3PLUS.EXE software from Intel: http://tinyurl.com/QX3-Win7-Files Step 2. Download and install the QCODINSTL.EXE software from: http://tinyurl.com/QX3-Win7-Files Step 3. Download and extract the QX3 Drivers from: http://tinyurl.com/QX3-Win7-Files Step 4. Now, plug in the microscope. When the "Found New Hardware" wizard appears you will see a message saying that the driver installation was not successful. Click the Close box. You need to install the driver manually by following these steps: a. Click START - Select Devices & Printers b. Right-click on the Intel QX3 Icon and select Properties c. Click the Hardware tab - click Properties d. Click Update Driver - select "Browse my computer for driver software" e. Browse to the folder with the extracted QX3 drivers from Step 3. above. The driver software should install successfully. Before you run the QX3Plus program right click the icon, click on "Properties", click the "Compatibility" tab, check the box next to "Run this program in compatibility mode for:", then choose in the drop-down box "Windows 98 / Windows ME". You should also check "Run as Administrator" if your account is a "Standard user". Step 5. Now double-click on the QX3+ icon on the desktop and the program should run. ------------
9/16/2017 4:27:55 PM • Intel Play QX3... • Answered on Sep 16, 2017
Windows 7 driver
Here are the instruction for installing the QX3 (or QX3+) Microscope with Vista and Windows 7. You must be using a 32-BIT VERSION. The QX3 is not compatible with 64-bit versions. Note, DO NOT use the software from the CD that came with the microscope. DO NOT plug in the QX3 microscope until Step 4. Step 1. Download and install the QX3PLUS.EXE software from: http://tinyurl.com/QX3-Win7-Files Step 2. Download and install the QCODINSTL.EXE software from: http://tinyurl.com/QX3-Win7-Files Step 3. Download and extract the QX3 Drivers from: http://tinyurl.com/QX3-Win7-Files Step 4. Now, plug in the microscope. When the "Found New Hardware" wizard appears you will see a message saying that the driver installation was not successful. Click the Close box. You need to install the driver manually by following these steps: a. Click START - Select Devices & Printers b. Right-click on the Intel QX3 Icon and select Properties c. Click the Hardware tab - click Properties d. Click Update Driver - select "Browse my computer for driver software" e. Browse to the folder with the extracted QX3 drivers from Step 3. above. The driver software should install successfully. IMPORTANT: Before you run the QX3Plus program for the first time, right click the "Intel Play QX3 Microscope" icon on the desktop, click "Properties", click the "Compatibility" tab, check the box next to "Run this program in compatibility mode for:", then choose "Windows 98 / Windows ME" in the drop-down box. You should also check "Run as Administrator" if your account is a "Standard user". Click "Apply" then "Ok". Step 5. Finally, double-click the "Intel Play QX3 Microscope" icon on the desktop and the program should run. If you get a message that the microscope is not plugged in, quit and restart the program. If the program hangs or crashes, reboot the computer, then restart the program. ------------ Comments and suggestions to mmehall [at] yahoo.com ------------
10/30/2014 3:10:13 AM • Intel Play QX3... • Answered on Oct 30, 2014
I was given QX3, not QX5 software with instructions in German. My computer is windows 7. should I still install the two intel play disks which came with the computer microscope. Can I install i
8/18/2014 8:58:10 PM • Intel Play QX3... • Answered on Aug 18, 2014
I have XP and the qx3 software runs but it won't recognize the microscope
Before you run the program, right click the icon, click on "Properties", click the "Compatibility" tab, check the box next to "Run this program in compatibility mode for:", then choose in the drop-down box "Windows 98 / Windows ME". You should also check "Run as Administrator" if your account is a "Standard user".
8/18/2014 8:54:36 PM • Intel Play QX3... • Answered on Aug 18, 2014
Need a qx3 driver for mac
The miXscope software works great. It is $18 from: miXscope Mac Microscope Software The free Macam software works on older Macs with OS 10.5 (Leopard) but has trouble with newer versions. Give it a try: macam USB webcam support for Mac OS
8/17/2014 6:08:38 PM • Intel Play QX3... • Answered on Aug 17, 2014
Digital blue qx3 drivers
8/11/2014 12:28:31 AM • Intel Play QX3... • Answered on Aug 11, 2014
Here are the instruction for installing the Intel QX3 (or Digital Blue QX3+) Microscope with Windows 7 or Windows 8.1. You must be using a 32-BIT VERSION of Windows 7 or 8.1. Note: The QX3 is not compatible with 64-bit versions of XP, Vista, Windows 7 or 8. Note, DO NOT use the software from the CD that came with the microscope. DO NOT plug in the QX3 microscope until Step 4. Step 1. Download and run the QX3plus.exe program from: http://tinyurl.com/QX3-Win8-1 After the program installs, uncheck "I would like to view the README file." Click "Finish". Step 2. Download and run the qcodinstl.exe program from: http://tinyurl.com/QX3-Win8-1 If asked about NTVDM, click "Install this feature" then click "Close" Step 3. Download IntelQX3driverXP.zip and save (do not open) the file from: http://tinyurl.com/QX3-Win8-1 Step 4. Now, plug in the microscope. The driver should load silently. If the "Found New Hardware" wizard appears and you get a message saying that the driver installation was not successful. Click the Close box. You need to install the driver manually by following these steps: a. Right-click START - Select "Device Manager" b. Right-click on the Intel QX3 Icon and select "Update Driver Software", select "Browse my computer for driver software" e. Browse to the Download folder with the extracted QX3 drivers from Step 3. above. The driver software should install successfully. IMPORTANT: Before you run the QX3Plus program for the first time, right click the "Intel Play QX3 Microscope" icon on the desktop, click "Properties", click the "Compatibility" tab, check the box next to "Run this program in compatibility mode for:", then choose "Windows 98 / Windows ME" in the drop-down box. You should also check "Run as Administrator" if your account is a "Standard user". Click "Apply" then "Ok". Step 5. Finally, double-click the "Intel Play QX3 Microscope" icon on the desktop and the program should run. If you get a message that the microscope is not plugged in, quit and restart the program. If the program hangs or crashes, reboot the computer, then restart the program. ------------ Comments and suggestions to mmehall [at] yahoo.com
8/11/2014 12:26:56 AM • Intel Play QX3... • Answered on Aug 11, 2014
QX3 microscope
Here are the instruction for installing the QX3 (or QX3+) Microscope with Windows 8 and Windows 8.1. You must be using a 32-BIT VERSION of Windows 8 or 8.1. Note: The QX3 is not compatible with 64-bit versions of XP, Vista, Windows 7 or 8. Note, DO NOT use the software from the CD that came with the microscope. DO NOT plug in the QX3 microscope until Step 4. Step 1. Download and run the QX3plus.exe program from: http://tinyurl.com/QX3-Win8-1 After the program installs, uncheck "I would like to view the README file." Click "Finish". Step 2. Download and run the qcodinstl.exe program from: http://tinyurl.com/QX3-Win8-1 If asked about NTVDM, click "Install this feature" then click "Close" Step 3. Download IntelQX3driverXP.zip and save (do not open) the file from: http://tinyurl.com/QX3-Win8-1 Step 4. Now, plug in the microscope. The driver should load silently. If the "Found New Hardware" wizard appears and you get a message saying that the driver installation was not successful. Click the Close box. You need to install the driver manually by following these steps: a. Right-click START - Select "Device Manager" b. Right-click on the Intel QX3 Icon and select "Update Driver Software", select "Browse my computer for driver software" e. Browse to the Download folder with the extracted QX3 drivers from Step 3. above. The driver software should install successfully. IMPORTANT: Before you run the QX3Plus program for the first time, right click the "Intel Play QX3 Microscope" icon on the desktop, click "Properties", click the "Compatibility" tab, check the box next to "Run this program in compatibility mode for:", then choose "Windows 98 / Windows ME" in the drop-down box. You should also check "Run as Administrator" if your account is a "Standard user". Click "Apply" then "Ok". Step 5. Finally, double-click the "Intel Play QX3 Microscope" icon on the desktop and the program should run. If you get a message that the microscope is not plugged in, quit and restart the program. If the program hangs or crashes, reboot the computer, then restart the program. ------------ Comments and suggestions to mmehall [at] yahoo.com
8/11/2014 12:23:58 AM • Intel Play QX3... • Answered on Aug 11, 2014
Intel Play QX3 Monocular Microscope Application Software
The QX3 files are now located at: QX3 Files for Win7 Comments and suggestions to mmehall [at] yahoo.com
8/11/2014 12:16:56 AM • Intel Play QX3... • Answered on Aug 11, 2014
Need driver for intel qx3 microscope with windows 7
The Windows 7 Files are now located at: QX3 Files for Win7 Comments and suggestions to mmehall [at] yahoo.com
8/11/2014 12:14:57 AM • Intel Play QX3... • Answered on Aug 11, 2014
Have QX3+ driver for my intel play microscope but poses a problem
Uninstall the existing Intel microscope software and then follow the following instructions:
Instruction for installing the QX3 or QX3+ Microscope with Vista
Step 1. Install the QX3PLUS.EXE software downloaded from Intel:
http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&Inst=Yes&ProductID=160&DwnldID=4419&strOSs=All&OSFullName=All%20Operating%20Systems&lang=eng
http://www.intel.com/support/intelplay/qx3/sb/cs-016002.htm
http://hyperslug.s3.amazonaws.com/IntelQX3driverXP.zip
When the "Found New Hardware" wizard appears, select "Locate and install driver software (Recommended)", a message "Installing device driver software" will appear. If you click on "details", you will see "Searching Windows Update", after a while you will be able to select "I don't have a disc. Show me other options" and browse to the folder with the extracted QX3 drivers from Step 3. above. The hardware should install successfully.
Double-click on the QX3+ icon on the desktop and the program should run.
1/30/2014 3:46:29 PM • Intel Play QX3... • Answered on Jan 30, 2014
I am trying to gey
http://download.cnet.com/Intel-Play-QX3-Microscope/3000-2110_4-104288.htmlworked for me Win 7 64 bit. May need to use compatibility mode (look it up separate problem if that's the case)
10/19/2013 5:45:51 PM • Intel Play QX3... • Answered on Oct 19, 2013
Intel play qx3 for windows vista i know that this
http://download.cnet.com/Intel-Play-QX3-Microscope/3000-2110_4-104288.htmlshould be even more compatible with Vista then Win 7. Have you tried running these programs in compatibility mode?
10/19/2013 5:45:37 PM • Intel Play QX3... • Answered on Oct 19, 2013
Qx3miroscope driver for windows 7
10/19/2013 5:44:02 PM • Intel Play QX3... • Answered on Oct 19, 2013
Use with windows vista
http://download.cnet.com/Intel-Play-QX3-Microscope/3000-2110_4-104288.htmlWorks for me Win 7 64 bit - same basic OS as Vista. May need to run in compatibility mode, I can't remember. That's a windows Vista/7 feature that allows you to run old 32 bit Win XP programs (right click I think)
10/19/2013 5:43:01 PM • Intel Play QX3... • Answered on Oct 19, 2013
Intel Play QX3 Monocular Microscope Logo
92 questions posted
Top Intel Science & Laboratory Experts
ADMIN Eric
ADMIN Eric
Don A
Don A
Collins Mccoy
Collins Mccoy
Are you an Intel Science and Laboratory Expert? Answer questions, earn points and help others
View Most Popular
  • Intel Science & Laboratory
Most Popular Question
need drivers intel play qx3 windows 7
  • Science & Laboratory
