20 Most Recent Toshiba Equium 100 PC Desktop Questions & Answers
0answers
Memory
Be the first to answer 2/9/2014 3:13:02 AM • Toshiba Equium... • Posted on Feb 09, 2014Be the first to answer
I have Toshiba f30, its fans run slowly than
Ah! I posted an answer on your other question but I didn't get it right! Now it makes more sense. You cleaned up all and changed thermal paste on cpu. Might be a problem with a fan itself. Only thing that pops in my mind might be a problem with bearings, but if fan is fine i'm afraid thermistor on motherboad is fried.
10/31/2013 12:14:26 AM • Toshiba Equium... • Answered on Oct 31, 2013
System in safemode, restart windows
  • Hello info88784, "I've read your situation, and I suggest that you can do the following. "Restart the computer, once you see the "Prompt Screen" to Press F2 or Press F12, quickly "Tap! the [DEL]key, located at the top [Right]next to the Scroll Lock, and END keys." You will know if you done it correctly, when you see the {Windows Boot Manager} Heading on the screen; at the bottom of the screen, it will read "Recovery Environment." Note: The wording may differ depending on the type & model computer you have. Now, there will be a long list of "Options" to choose from, select the option that best describes; Try each to fix the problem: Startup Repair, "Repair My Computer, and System Restore; or next time, "Press the [F8] button the next time you "Bootup" and choose the more {Advanced Options} select whatt best decribes; " In the [Systems Recovery] windows, "Configure Last Known Good Boot!" Follow all the instructions, and I hope all goes well. "I would appreciate if you could find the time to give a "Helpful Rating, its my only reward," knowing I could be of assistance! Thanks alot, paul7of9
12/10/2010 9:43:44 PM • Toshiba Equium... • Answered on Dec 10, 2010
Can't use Internet printer etc,
When in safe mode almost all drivers (the instructions the computer uses to operate a device) are disabled. To fix this, restart your computer and load windows normally.
12/10/2010 8:40:25 PM • Toshiba Equium... • Answered on Dec 10, 2010
My ethernet diver doesn't work
go to toshiba.com and download free ethernet driver!
8/17/2010 10:22:42 AM • Toshiba Equium... • Answered on Aug 17, 2010
Equium 100 PC Desktop: my sscreen has rotated on my Toshiba EQUIUM A100-0...
hold ctrl+alt and press the up or down key to change the screen to its original position
5/5/2010 2:58:46 PM • Toshiba Equium... • Answered on May 05, 2010
Toshiba Equium A100-02k laptop black screen
sounds like it could be the monitor itself
4/23/2010 5:27:32 PM • Toshiba Equium... • Answered on Apr 23, 2010
Error in toshiba laptop
Toshiba Factory Reset
This link shows you how to use the partition http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/bulletinDetail.jsp?soid=2291088&pf=true basically as the PC boots TAP F8 key - from the menu that appears choose "repair your computer"
If that option is NOT available then you will need to Order CDs from Toshiba - http://laptopforums.toshiba.com/t5/System-Recovery-and-Recovery/Recovery-media/m-p/9148#U9148
4/14/2010 10:36:18 PM • Toshiba Equium... • Answered on Apr 14, 2010
My Toshiba Equium laptop will not read CDs or DVDs
Is CD/DVD showing in my computer?
Are you reading retail or homemade CDs?
Use retail to test reader, any will do.
Not all homemades work in all readers.
Look here:
http://repair.laptopsinfo.net/How_to_open_toshiba_equium_laptop
4/4/2010 1:44:50 PM • Toshiba Equium... • Answered on Apr 04, 2010
2answers
Desktop portrait or landscape as needed.
Depending on the Video card, you can usually select "Rotate" from the icon in the left hand toolbar at bottom left, usually an ATI, Or NVIDIA card, click on the icon, and get into the menu,you should find it there. As I say it is card Dependant Or click Properties on the Video card and select it from there..
3/11/2010 2:36:30 AM • Toshiba Equium... • Answered on Mar 11, 2010
3answers
I´ve a toshiba Satellite a215. How can I get the recovery disks?
As far as many of us know, you has to buy the recovery cd, but, instead of going to all the trouble, since you might has to either call or contact them via e-mil.
Since you already clean the system, why not go to the site and download all the drivers for your specific system, is very simple, and you get to load just the programs you need.
Drivers are a must, here is the direct link, choose download then choose your system > system model>"GO"
the next page would be all of your drivers, you can use your other system or a friend, put then on a flash drive or burn into cd.
Before you do any driver install, you should make sure you are connected to the internet, and do the windows update, as there should be new drivers for your system.
You should also do an "intel INF" update if not provided at the toshiba site, use google and downloaded it, make sure it applies to your system.
After you done the inf update and windows update, now you install all of the drivers and utilities that are available to you at the site.
sorry can't be of more help, below is the link to the site
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/home.jsp
2/7/2010 12:22:00 AM • Toshiba Equium... • Answered on Feb 07, 2010
3answers
My toshiba equium L100 186 " laptop" willnot power up.
replace motherboard
12/8/2009 11:03:57 PM • Toshiba Equium... • Answered on Dec 08, 2009
My toshiba equium laptop keeps randomly turning
Hi:
your symptoms point towards a intermittent cooling problem...You might need to remove your cpu cooling fan, clean it up, and re install it, with new thermal paste. Make sure all fans in your computer are working as they should, including the power supply fan too.
11/20/2009 5:21:31 PM • Toshiba Equium... • Answered on Nov 20, 2009
I cannot change my main display on my toshiba
in the right hand of ur desktop screen, u find graphic option.
U jst adjust 4m here, to display portrail to landscape.
11/14/2009 4:15:48 AM • Toshiba Equium... • Answered on Nov 14, 2009
2answers
Change potrait view to landscape view on HP 6530B laptop
To change the display from portrait to lanscape
Press Ctrl-Alt plus a left or right arrow key.
ALSO
Upside down display is caused by unintentional pressing Ctrl-Alt plus the down arrow key.
Restore by pressing Ctrl-Alt plus the up arrow key.
11/8/2009 10:38:27 AM • Toshiba Equium... • Answered on Nov 08, 2009
DVD ROM won't read disks . Toshiba Equium
YOU SHOULD GO THO TOSHIBA SERVICE CENTER AND YOU CAN REPAIR IT ON ANY COMPUTER SHOP
10/21/2009 1:59:45 PM • Toshiba Equium... • Answered on Oct 21, 2009
Toshiba dvd drive
check for its functionality in safe mode,. if it still cant explore hwats on your disk, delete upper and lower filter, if no go replace dirve.
9/12/2009 12:15:19 AM • Toshiba Equium... • Answered on Sep 12, 2009
Toshiba satellite laptop doesn't work after ipod removal
format and install a new operating system..start fresh
8/31/2009 7:04:36 PM • Toshiba Equium... • Answered on Aug 31, 2009
I cannot connect to the internet with my laptop Toshiba?
You need to get the IP address, domain and other info from you internet service provider to set up the connection again.
8/21/2009 7:35:23 PM • Toshiba Equium... • Answered on Aug 21, 2009
Toshiba Equium 100 PC Desktop Logo
33 questions posted
Top Toshiba Computers & Internet Experts
ExpressFiX
ExpressFiX
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
Equium Toshiba
  • Equium Toshiba
Most Popular Question
ethernet diver doesnt work
  • Computers & Internet
