20 Most Recent Toshiba Satellite A75-S209 Notebook Questions & Answers
Guides to dis-assembley
Toshiba... | Answered on Jan 09, 2014
Restore Toshiba to Out of the Box Condition
If your model Toshiba laptop has a Restore partition on the hard drive then follow these steps to restore your Toshiba to the Out of the Box condition.
1. Press and hold the 0 (zero) key and at the same time, tap the power button once to switch on
your notebook.
2. When the machine Starts beeping; release the 0 key.
3. When prompted by the warning screen; select Yes to continue with the system recovery.
4. Select Recovery of Factory Default Software; click Next.
5. Select Recover to out-of-box state. 6. Click Next again.
7. Click Next to Start recovery.
8. Restart the Toshiba laptop when there restoration process finishes running. Follow the prompts that appear on the screen to set up the laptop's date, time and language settings.
Toshiba... | Answered on Aug 22, 2012
you can look on ebay for the keys, look for your specific laptop model because keyboards tend to vary from one to the other. you can use white out or something along those lines and then put a clear layer of nail polish over it, but anything you do like that would look kind of tacky imho, so i'd just purchase new keys.
If you need further help, reach me via phone at https://www.6ya.com/expert/joel_63c670a84e9f6a97
Toshiba... | Answered on Jun 12, 2012
You need to turn off the Number Lock. Press the ScrLk/NumLk key it is located near the F11 key. When you turn off the number lock the NumLk LED light will also switch off and you will get letters instead of numbers.
Toshiba... | Answered on Feb 21, 2012
The Munber Lock has been selected.
Try pressing the ScrLk/NumLk key that is near the F11 key.
This will turn off the Number lock and the number lock LED.
The used inverter maybe faulty. The inverter supplies high voltage to the CCFL lamp in the LCD screen, the CCFL lamp provides the backlight.
LCD screens and Inverters are available from this WEB site.
www.lcdparts.net
Toshiba... | Answered on Feb 16, 2012
your computer can be upgrade up to 1.5 gigabytes of ram with a PC2700 memory specifcation compliance.
Toshiba... | Answered on Sep 04, 2011
If it has had a over heating problem in the past it may need to be service and have the thermal paste reapplied even if the fans were clean and air is flowing if the thermal paste has crystallized on the cpu it will still overheat. Could be drivers are you getting a blue screen when it fails.
Toshiba... | Answered on Jul 04, 2011
Briefly press the main on/off switch. It should bring it out of hibernation.
Toshiba... | Answered on Jun 26, 2011
I had an old thinkpad that i needed a screen for...i believe I ordered it off ebay...and it was under 100 dollars...go to ebay and try it
Toshiba... | Answered on Jun 11, 2011
Try using a different adapter and see if the problem persists. If so, then change the power supply and try using a new adapter again.
Toshiba... | Answered on Apr 10, 2011
change browser like opera
Toshiba... | Answered on Feb 11, 2011
Toshiba Satellite A75-S209 Notebook Logo
68 questions posted
Top Toshiba Computers & Internet Experts
Ekse
Alun Cox
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
Satellite Toshiba
  • Satellite Toshiba
Most Popular Question
suggested way toutching up lettering
  • Computers & Internet
