Toshiba a45-s120 laptop mouse pad is frozen
“Hi let’s see if we can fix this problem”
I. “To “Enable” the Pointer Device using the Touch-Pad, go to, Control Panel, click (“Mouse”) in the “Hardware and Sound” category; go to, “Device Settings” in the (Devices) block.
II. “Highlight”; the item you want to (enable) this being the “Pointer Device.” Click the (Enable) button, just below. Be sure to (Click) on the “Apply” button, and click OK.”
III. You may need to “Update Drivers?” Click on “Hardware, click “Properties,” click, on Driver.” If the, Update Driver (block) is not “Grayed-out” click “Update Driver”, click (OK), this will ensure that the application take effect. Note: Restarting the computer will configure system changes in the computer applications to prevent errors, and to finalize the (Installing / Uninstalling) of programs, and or (Enabling / Disabling) of Hardware.
To setup the Internet Connection: To Start, go to the “Control Panel,” you want to open the “Internet Options” window. Click on the “Connections” block, click the “Setup” button, and follow all the instruction carefully. “Important! Always click “apply, ok, and restart the computer after making changes to the computer.”
"Did this solution help?"
2/1/2010 3:27:53 AM •
Toshiba...
Answered
on Feb 01, 2010
