20 Most Recent
Curtis 326A LCD TVDVD Combo Questions & Answers
Have a curtis tv , trying to run autoscan, it
For the auto scan to detect there must be channels present on the CABLE that is connected to the RF input- TUNER INPUT- of the TV.So check with your cable operator for the channels and you can connect. however if you are using a digital box then the channels are memorised on the box as only the output of the box is connect to the video/audiop inputs of the TV. if so select line in/video 1/2.
Where do I get the firmware for Curtis DVD playere
To get the firmware for your Curtis DVD player, you will need to contact the manufacturer or visit their website. The firmware is the software that runs on the DVD player and controls its functions. It is important to keep the firmware up to date in order to ensure that the DVD player is operating properly and to take advantage of any new features or bug fixes.
To get the latest firmware for your Curtis DVD player, you can try the following steps:
- Visit the Curtis website and navigate to the support or downloads section. Look for a section that lists firmware updates for DVD players.
- Download the latest firmware update for your specific DVD player model.
- Follow the instructions provided by the manufacturer for installing the firmware update. This may involve creating a bootable USB drive or inserting a CD into the DVD player.
- Once the update is installed, restart the DVD player to complete the process.
If you are unable to find the firmware on the Curtis website or if you have any difficulty with the update process, you can contact the manufacturer for assistance. They may be able to provide further instructions or assistance.
Curtis TV, Mod#LCD2443A: Picture died, Sound is OK. Which part needs replacement - Mother-board or sub-components? Is it a big job, or simple plug-in swap? Any cautionary info?
Thanks.
Dave
What way you think, working with an LCD TV is skilled work indeed. Here, as sound is OK, there should be something wrong with its picture circuit of the main board. You should have skill in working with main board of an LCD TV. If you haven't it will be best to contact any service technician.
If you wish to get some details; check the sites linked here.
https://elektrotricks.blogspot.com/
https://electronicshelponline.blogspot.com/
Faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault. Search the site by type in the Brand Name of your set, in its search bar at the right side column, and press enter. See it in by Webview with mobile or by desktop. Mobile View has no search box. Screen-shots to defective LCD panels are given. You can see and compare to that to your TVs', and can make sure about the fault to an extent.
Always respect voltages. While some may not be dangerous in themselves, they can cause unexpected reactions that are best avoided. Before reaching into a powered TV set, it is best to test the high voltage insulation. It is easy to do, and is a good service precaution.}
Curtis mathes tv model# v37ncgi blinking red light do to have a diaogram of where capulators are located?
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
https://homenol.blogspot.com/
Blinking codes details to many popular brand TVs are given. If blinks continue without any pause, the main board is faulty. Search the sites by type in the brand name to your set, in its search box on the right column. View it on a desktop or in web View. Mobile view has no search box...
