20 Most Recent
KitchenAid Chefs Chopper KFC3100 3 Cups Food Processor Questions & Answers
Kitchenaid kfc 3100
Probably the mechanisms in either the bowl or the parts of the lid that engage the bowl mechanisms.
Lid is stuck in wrong direction will not come off
I got the lid off by using a turkey-skewer (i.e., a long pin) to push down on the long white plastic piece, in the handle, just above the spring.
When you push it down far enough, you can twist the cover back over to the proper side.
(We think we created this situation ourselves by mistakenly twisting the cover into place clockwise, rather than counter-clockwise.)
My kitchenaid food processor won't work
Does the actuator push down far enough to catch the button at the bottom? I repaired one simply by adding a vinyl screw cover to the top of the button so it was tall enough to be reached by the actuator.
Recently moved to Australia.
Is there anyway I can
Without step-down transformers you are out of luck. I am sorry. I know the transformers are ugly but they are cheaper than replacing your food processor and espresso machine. One thing you could do is to contact Kitchen Aid and ask them if the motor can be wired for 240V. If not, ask them if you can purchase the 240V motor for your processor and replace it directly. As for the espresso machine, no idea...sorry.
I have a kitchenaid foodprocessor
food processors have interlocks between the bowl, the top and the base. Inspect to see that those are all making. When you lock the bowl to the base and the top to the bowl you should hear some clicks and see some interlock mechanisms line up at the back of the bowl.
