20 Most Recent
Sony KDFE60A20 60" LCD HDTV Questions & Answers
What causes picture to freeze?
the t-con board memory, it can also be the main av board as some have a pause screen feature that can sometimes be accessed from the remote, but some remotes dont have the button. but the memory failing is the cause. so its either the memory in the t-con board or the memory on the main av board. to find out what one it is you will need to remove the t-con board lead and plug back in a second later if the screen works its the t-con board if it stays frozen its the main avi board.
Kdfe60a20 6 blink
Yes the power supply board is notorious for blowing caps and tv repair kits .com has a good DIY kit for this problem.
Sony kdfe60a20 wont stay on
When it goes on does it come on with a very dim screen and then shut off?When its off what lights on front (led) are blinking?
I NEED CODES FOR MY NEWSTAR NTR-B28Z FOR MY SONY TV
ChatGPT 3.5
User
I need code for newstar ntr b28z for my Sony tv
ChatGPT
Unfortunately, I can't provide specific code for your Sony TV remote without knowing the exact model number. However, you can usually find the code in the user manual of your Sony TV or by contacting Sony customer support. Alternatively, you can try using the auto-search feature on your newstar ntr b28z remote to find the correct code for your Sony TV.
User
ChatGPT
To find the code for your Sony TV using the Newstar NTR B28Z remote, you can try these general steps:
Turn on your Sony TV.
Press and hold the "TV" button on your Newstar remote until it blinks twice.
Enter the code for Sony TVs. Some common Sony TV codes are: 0000, 0011, 0080, 0111, 1234. If none of these work, you can proceed to the next step.
Press the "Power" button on the Newstar remote. If the TV turns off, the code is correct. If not, try a different code.
Once you've found the correct code, press the "TV" button again to lock it in.
If none of the provided codes work, you might need to consult the manual of your Newstar remote or contact their customer support for assistance.
