20 Most Recent
Graco Sweetpeace Soothing Center Questions & Answers
I have the graco sweet peace center but the motor
You can look for replacement parts at http://www.gracobaby.com/ReplacementPartsModelView?catalogId=65051&categoryId=76005&langId=-1&storeId=65051. As far as a warranty, you can call Graco at
1-800-345-4109
I have a Graco baby monitor, it started making a
Annoying! happens to us too frequently, but this works. We ended up buying a new one and returning our broken one after owning for three months
From Manual:)
5. Turn on the Nursery Unit using the On/Off switch on the side. The green power light should come on.
6. Within a few seconds, the Parent Unit will lock on to the Nursery Unit and the top four (4) green LEDs will shut off.
A second later, you will hear a series of beeps and the connection LED should change from red to green. Your monitor is now
ready for use.
7. If the top four (4) LEDs do not shut off, power off the Parent Unit and the Nursery Unit and repeat steps 4 and 5 above.
8. If the connection LED on the Parent Unit does not change from red to green and the unit begins to beep, press the
channel "ch" button on the Nursery Unit. Within a few seconds, the Parent Unit should lock in on the Nursery Unit and
the connection LED should change from red to green. You may hear an audible beep during this process.
9. If the Parent Unit is still unable to lock in on the Nursery Unit (connection LED will be red and the unit will beep), power down
both the Parent Unit and the Nursery Unit. Wait for 10 seconds then hold the volume down button on the Parent Unit while
pressing the On/Off switch. When the unit powers up, you will hear a single beep and all of the soundlights will illuminate.
Release the volume down switch and within 2 seconds you will hear two beeps and all of the Sound Light LEDs will stay lit and
the bottom LED will be red.
10. Repeat steps 5
Head supports for baby
We would recommend you contact Graco customer services.ECER44 03 is the standard of the carseat, to show it meets regulations.
Nursery unit of my graco monitor shows a brief red
There is an internal problem in the circuit board inside the monitor....
When the power starts to flow it heats up and opens the circuit...
This will cost more then the monitor is worth to try to fix...
heatman101
My Pal Scout needs replacement battery spring..
I would perform a test use of the spring before purchasing it to reach this conclusion. You can call ahead to several part stores that you've identified to carry the spring and request if test use is possible. Then, work with the stores that say "yes". Thank you.
9/30/2022 5:41:42 PM •
Baby Care
Answered
on Sep 30, 2022
Tomy baby monitor srv 400 instruction
Hi
I have Tomy srv 400 but the parent unit is not working. I have attached a photo to show what its giving me when plugged.
If anyone knows how to fix it.
Thank you
4/1/2019 11:49:08 PM •
Baby Care
Answered
on Apr 01, 2019
I feel REALLY down, I Am Never Going To Get A Baby Girl?
Other
people would say, it does not matter what gender your baby will be and
that is a natural reaction but to some, this is a serious concern. Stop
worrying, Gender Selection Clinic
is the solution to your problem if you are really serious about it.
Technology and science have made it possible for people to get pregnant
and to choose the gender of their kids. The embryo gender selection IVF
is being performed by medical doctors around the world. This system has
been proven for decades. The success rate of having a girl is 93%. This
method though is a bit expensive but if you really want it, then the
cost would not be a problem to you. Both you and your husband must have
an open mind on this. Otherwise, it will create misunderstanding between
the two of you.
8/15/2018 7:03:40 AM •
Baby Care
Answered
on Aug 15, 2018
Is it dangerous to wear the wrong size of nursing bras?
Usually a woman's breasts engorge very quickly after giving birth and take a few weeks to gain a stable size, usually one size bigger than what she had before giving birth.Because of the quick and unpredictable extent of ****** growth some women end up wearing the wrong bra size, and while wearing a bigger size may just turn out to be uncomfortable, wearing a smaller bra size while breastfeeding may reduce their milk supply and cause a painful infections called mastitis.
4/3/2018 2:57:56 AM •
Baby Care
Answered
on Apr 03, 2018
