20 Most Recent
Dell Inspiron 15R Laptop Questions & Answers
How can i tell if my keyboard is backlit in inspiron 15r?
If you press any key on the keyboard, the back light should come on automatically. If not, hold down (Fn) function key and press "right arrow" with a blue florescent symbol until the back light is lit. Pressing the "right arrow" key while holding down the (Fn) key lits the back light and can also reduce, increase the light.
Hope this helps
4-4-2 beeps
It might be a hardware fault. Have you tried scrubbing your RAM and reconnecting your hard disk? Sometimes, this solve the problem. If it don't, you can also try changing your RAM, owned by someone else, that is working and place it in your laptop just to cross check if your ram is faulty. You can also use the diagnostic ram tools built by dell themselves to check for fault. :P
Seagate is not detecting in my pc
if a drive is not detecting it may be badsata drives will either give failure messages or wont detect at all if the drive is bad.ide drives may do this if the jumper setting is wrong.most of these drives are usually set to cable select.but if they may need to be set to the right position in relation to the ide cable
Dell insiron1505 monitor goes dark
Could be backlighting, loose ribbon cable, tiny switch that turns the monitor on and off when lid is opened and closed. Even a driver issue. Can you see a "ghost image" of your desktop in a very bright light? Has the laptop beed jarred, dropped, fallen over...etc.?
Window system32 config
I would recommend to login with Safemode. Scan PC with an updated Antivirus. Also scan PC with a registry cleaner to fix windows errors. Use Reginout to fix windows errors.
Blutetooth driver was not instaling for my laptop
are you talking about the inbuilt bluetooth or any usb bluetooth dongle.if it is inbuilt one then check if you have bluetooth chip installed in it! contact dell care,give your service tag number,they will say it.
Laptop touchpad has disabled how do I re enable it
Hello ania1997,"!Beware, you'll have to "Manually Navigate,"without the 'mouse. You will use the "Tab, Arrows, and 'Enter' buttons,to perform the tasks!"
First, click on the "Start Button."
Now, click on the "Control Panel," in the 'start menu'.
Scroll in the Control Panel, and select the "Mouse" applet!
Open the [Mouse Properties], by 2x clicking or,
Right clicking, and open.
From here you want to ["Enable the Touchpad Device"].
If you need help with anything else?
"Write a 'comment'; I'll be here to assist you!"
"Best Regards"
How do you install a hard drive
Larry provides great answer up there ^^^ which is better down here.
Larry Ng Jun 23, 2022
NO PC told (dell has 10000 models)
no OS told, windows what"?
no drive told.
my wild wild guess is the boot drive is locked.
and you are attempting and ******* act. to it.
like deleting key parts of a running OS (windows) (like deleted tires on rims of 85mph moving car, fails)
no real goal told, but the nebular "install HDD"
one can add a 2nd drive easy or any of 1000s of external HDD models or external or internal, SSD or even a thumb drive. (vast) (just 2 steps in fact)
but the boot drive , change out is far far far more complex. and you never not told that.
you want to mess with the C: drive?
now let me guess the real goal (sad I must)
the OS drive windows is failing ( common)
and some lil' bird told you it needs a new boot drive, and then fail to say so here.
okay I will bite.
1: buy a new SSD (hdd fail and are slow)
2: buy a new OS, from MS. or get free w10. (ask how)
3: then put in new SSD,
4: run the w10 installer media (it is free)
5: load w10 to the SSD fresh
6: answer the silly 30 questions it asks.
7: and click activate. (buy it)
How do i change admin password
can;t log in now or what?
what does change mean,
lost it and now can not get in
or means just want to change it , logged in.
NO PC told and NO OS told
or if bios admin or windows admin.
bios or windows.
both are hacking./ if lost.
so google the cure.
How do i eject a cd from the laptop
push the physical cd drive try button marked EJECT
the PC must be running,
or use the paper clip hole trick. (if PC is dead or tray jammed)
google that. clip trick
the dell manuals covers this
