20 Most Recent
Samsung PN59D6500 3D Plasma TV Questions & Answers
My Samsung Plasma TV PN59D6500DF turns on, displays the samsung log, then displays hdmi2 for a few seconds then turns off and restarts. Remote does not do anything.
Fault at its main digital board.
Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
http://electro-medical.blogspot.com/
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Before going further; try a hard reset first. If it does not help you, replace the main digital board. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; visit the site linked here.
9/12/2016 4:08:01 AM •
Samsung...
Answered
on Sep 12, 2016
Samsung tv cycles on and off. Replaced the Y main or Y sustain and it didnt solve the problem.
6/2/2016 12:07:25 PM •
Samsung...
Answered
on Jun 02, 2016
My Samsung TV is cycling its power on/off, what parts need to be replaced?
Samsung have had trouble with power supplies in the past. I worked in a company that had a large number of Samsung TVs and we would have a least 2 or 3 each year that had to have power supplies replaced. We had a repair agent do this for us and from memory cost us around $250 Australian.
3/24/2016 1:02:48 AM •
Samsung...
Answered
on Mar 24, 2016
Samsung pn59d6500df display turns off after 5 minutes. Comes back on when unplugged for a while. Cannot see any bad caps.
Fault to the main power supply regulator section. Either it will be on a separate board, or on the part of its main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
If Vs & Va voltages will differ to an extent, this type of fault can occur to Plasma TVs. The adjustment to these voltages are possible, and the adjustments presets are there at the power regulator board. Please contact any service technician before replace the power board. Even though you replace this board, you have to adjust the above said voltages after fitting the new power board too.
10/2/2015 7:18:31 PM •
Samsung...
Answered
on Oct 02, 2015
Remote does not work
easy way to check remotes if there working, is to use the camera on your phone and point the remote at the phone and hit some buttons, you will see the invisible UV light the remote uses threw your phone.
If no light is seen might be a battery or battery contact issue, try spinning the battery's while doing the test... KOOL huh
Jay the pool pump motor repair guy in longwood Florida
remember to thumbs up. thanks.. J
2/8/2014 3:12:16 AM •
Samsung...
Answered
on Feb 08, 2014
Samsung plasma TV PN63A650 will not turn on, just makes continuous clicking.
the capacitors seem to have gone bad if they have like a black dot on them it is a sign they have actually blown they can be replaced by placing new ones on but it would be better if the board was replaced (unless you wish to replace those capacitors please please do be careful in doing so they hold enough charge to give you a bad zap even kill if one isnt careful)
Samsung 60 inch plasma not turning on. Unplug HDMI and turns on. Let it warm up (15min) then one HDI (720) works. Replaced caps but no change.
Before going further; try a hard reset first. If it does not help you, replace the main digital board. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; visit the site linked here. ..
Samsung Plasma..clicking pn50a400c2dxza
Have you checked the sustain board/s. If you wish to get some details about how to check a plasma TV, visit the site linked here. It has details with illustrations. The shown is for an LG brand plasma, but all the plasma TVs will have same configuration and checking procedure, irrespective of its brand and screen size.
Pull up older posts. Surf the site with patience.
