20 Most Recent
Toshiba 46SL417U LCD TV Questions & Answers
TV won't turn on
Had same problem but it was under warranty it was control board going out. It started like yours then eventually Icouldnt change anything on tv even with buttons on tv or remote
What is a freeview board
freeview board is just what it says it is. picks up digital signal from the aerial can be a number of channels in one code.ie analog has one chanel to one code number say 32 on search. on the same code number in digital 32 will have any were for 5 - 20 tv channels on just this one code number it save the channels to the listings.
You turn on the TV, the green light flashes 3
have you had the freeview board off and used tv with it not on. sometimes the built in free view board can fail and use the processor speed up. so no menu etc also will affect the inputs..
Toshiba 46sl417u what does the T-con board control
This board takes the video signals from the signal board and converts it to the correct format to properly let the panel present the picture. It acts like a buffer that also corrects for gamma and sometimes controls the back lighting for dynamic contrast.
Tv stops responding to remote after 10 minutes
I have same issue and not just remote even controls on tv do not work. Eventually hitting power button will turn it off then I can turn on and have functions for 3-10 minutes. Wish someone had a solution
