20 Most Recent
Dell Streak 5 Android Tablet Questions & Answers
Pattern attempts
hi! my tablet dell streak 7 said too much pattern attempts what to do
Dell venue 3730 lockscreen bypass
Hardware Key Reset
If your device is not working because it is frozen then you wouldn't be able to reset it with the software. So the next option would be the hardware method.
1. Press and hold down the Power button + Volume down button + Camera button all at the same time until the device vibrates, now let go of the Power buttonwhile continuing to hold down the Volume down button and theCamera button.
2. Shortly you should see the message displaying "Are you sure you want to format?", you can now release the Volume down button + Camera button.
3. In the format screen you have the option to either Format or Cancel. Tap on Windows key Format if you are confident to go ahead.
4. Press on the Windows key again to confirm your choice.
Your device should now begin to format the device and shortly should startup with the Start-up Wizard. Ensure you device have the battery power while doing this
