20 Most Recent
LG KP500 Cell Phone Questions & Answers
Not getting network coverage
Contact your provider, you probably need to configure the seetings, they could send you a special configuration SMS.
Lg kp5oo no power
1.Check the device's battery level for at least two bars of strength. 2.If the battery level is low, charge the battery. 3.If the issue is not resolved, remove the back cover. 4.Remove the battery. 5.Wait 10 seconds. 6.Press and hold the W key. 7.While pressing down the W key, re-insert the battery. •The device restarts and after approximately 15 seconds, the 'Recovery' screen appears•Release the power button but *continue holding the home button*, for another 30 seconds.StepThanks
Cant send mms bt can recieve
1. Open the "Menu" and then select "Settings."2. Tap "Connectivity," then "Internet profiles" and then "Add profile."3. Enter "#Profile" as the "Title." Select "Proxy" in the "Use proxy" field.'4.Change the "Proxy server address" to "#MMSProxy" and then "Proxy server port" to "#MMSPort."5. Select the existing access point from the list and click "Save".
