20 Most Recent Toshiba P000347580 - Satellite 1400&2400 Series Laptop Keyboard (P000347580KB) CD-ROM Drive Questions & Answers
dear sir
yes i can help u strongly... first of all u have to turn of laptop then connect yr laptop and tv then turn laptop on now when windows appeair. laptop screen has icon and other has plane wallpaper so now go to display propaties ( click on desktop>go to propaties>setting> now it's show's 2 monitor screen on display screen click in inditeficate... how it's show "Expand display " somthing like that just remove select earrow now click apply... if it's not worked go to advance then go to adaptor setting and find display setting and select "CLONE" it's male both laptop and tv screen as same...it's help u...:)
Thanks
please vote
jo_chinmay
Toshiba... | Answered on Feb 05, 2009
If you want to play DVDs from any region you maybe able to upgrade the firmware to make it region free BUT if you make a mistake or installed the wrong firmware the player will be a piece of junk.
The best solution to make the player region free is to install a piece of software (Passkey for DVD) that allows you to play DVDs from any region and Passkey for Blu-ray that allows you to play Blu-rays from any region.
There are several available on the Internet but my favourite is DVD-Region Free
www.dvdfab.com/products,free.htm
Toshiba... | Answered on Dec 05, 2019
Do you have a wifi card in the computer? It is a hardware part that you need so that the computer can connect to the wifi. If you have that but can't find it in the operating system. I suggest that you either install or update the driver for it.
You can use RadarSync to scan your computer for the available updates of your wifi driver. Make sure that you connect to the internet first using your ethernet so that it will detect the available driver updates somewhere in the databases of the manufacturer.
David
http://goo.gl/CxsY9u
Toshiba... | Answered on Sep 25, 2019
to get the driver for your Toshiba, follow the steps below:
go to http://support.toshiba.com/drivers
enter your laptop model ( Satellite L505) and download sound drivers and other necessary drivers needed for your laptop to operate well.
Good luck.
Toshiba... | Answered on Sep 12, 2019
uninstall the software and put it again
Toshiba... | Answered on Sep 06, 2019
All drivers are available free of charge from Toshiba's web site.
Toshiba... | Answered on Jul 23, 2019
toshiba satellite error 0xc000021a
Blue screen
Toshiba... | Answered on Jun 21, 2019
go to your browser proxy setting and make the proxy automatic
Toshiba... | Answered on May 21, 2019
check the power ic of the laptop with laptop technicians
use VLC it plays everything it even has extensions like subtitle downloader. VideoLAN Official page for VLC media player the Open Source video framework
Toshiba... | Answered on Apr 29, 2019
Take another video and don't drop your gear. The mishap obviously ruined the original.
Toshiba... | Answered on Apr 02, 2019
Remove the battery and see if it starts up fine, if not then try the following:
1. Unplug your charger cord.
2. Remove the battery.
3. Press and hold the "Power" button for 30 seconds or longer
4. Now plug back in the power/charger cord.
5. Now put the battery back in.
6. See if it starts up now, laptops often get stuck in hibernate mode.
Toshiba... | Answered on Nov 13, 2018
Follow the procedure:
Device Manager
USB Root Hub (USB 3.0)
Change driver, manually, to "Generic SuperSpeed USB Hub"
Now the hardware is working
Upgrade the driver again, automatically
Toshiba... | Answered on Sep 25, 2018
  • The CMOS is, in basic terms, the part of the motherboard that stores the BIOS settings. To remove the BIOS password from your Toshiba laptop, your best option is to forcibly clear the CMOS.
    To clear the CMOS, you must remove the battery from your laptop and leave it out for at least 30 minutes to an hour. The way to remove the battery from your Toshiba will largely depend on the model. A common way to remove the battery--particularly with newer models--is to release the battery lock on the bottom of the laptop, while sliding the accompanying tab over to the side. This will pop the battery out from its tray so that you can then pull it out all of the way out.
    Before you remove the battery, turn off the laptop and remove the AC adapter. Otherwise, you could end up harming yourself or the laptop components. You must also ground yourself to prevent damaging the laptop with static electricity.
    After about a half an hour or more, return the battery back to its tray and lock it into place. Power on the laptop. The computericon1.png, ideally, should no longer ask you for a BIOS password.
    It's important to keep in mind that resetting the CMOS means that all of your BIOS settings will be reset to factory default. Also, sometimes you may need to leave out the battery for much longer than an hour to reset the password.
  • If resetting the CMOS doesn't work, then your next bet is to try using a backdoor password. A backdoor password is basically a password that manufacturers include with the BIOS so that technicians can access the computersicon1.png that people send in for repair. An example of a Toshiba backdoor password is, unsurprisingly, "Toshiba." When the BIOS prompts you to enter a password, entering "Toshiba" may allow you to access your PC and clear the old BIOS password. Another option is to hold the left "Shift" key down while booting.
Toshiba... | Answered on Sep 23, 2018
ok like all old laptops the CCFL lamps are now dead.
all are. if used every day and 20,000 hours hit, bam DEAD.
the CCFL are dead,
all LT made before 2010 had CCLF back lamps.(and monitors)
you hear the fan blow?, and no text on screen? (2 things)
your 14year old (today) the screen CCFL lamps are bad.
do this, 5 minute work. ok> and tell what fan does.?????
http://www.pcdied.com/monitors_and_screens/flash-light-trick.html
Toshiba... | Answered on Aug 26, 2018
Computers & Internet Logo
1 questions posted
Top Toshiba Computers & Internet Experts
Ekse
Alun Cox
Thomas F. Schneider
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
Satellite Toshiba
  • Satellite Toshiba
Most Popular Question
use laptop tv laptop same time
  • Computers & Internet
