20 Most Recent
Dell Streak 7 Tablet Android Questions & Answers
Need user manual for android 3.2 honeycomb operating system
There is no manual for Android Operating System (OS) as such because different vendors (like Dell, Samsung, etc) can customize the OS. So no manual will work on all devices. You can however look at your product manual. Btw, for most of the common tasks you can do a simple search on internet and you will get the answer. Otherwise, just post the question here on fixya.
How do i delete pictures on the dell streak 7
Grant,
You can drag the photo to the top of the screen and drop it in the waste basket. The waste basket doesn't always appear until you start dragging the photo.
So, until you try dragging you don't see where the basket appears.
Thank You,
Dell-Jesse L
Dell Social Media and Communities
Why wont my dell streak 7 turn on
Hello.
You can check if the battery had somehow got out of it's place.
Also it may be a software related issue, as a fix you can first try to plug it using the usb cable to your computer.
Hope it helps
My Dell Streak 7 Tablet will not charge. When the
I can't charge my sell streak 7 (no orange and green color appear when plug in) moreover the unit can't turn on also.
I tyr hard rest also but no response at all
would you please suggest me how to do it
How can I fix the charging port on my Dell Streak 7?
Ok this is not a easy fix. The replacement port connectors are easy to get and cheap $4-$10. How ever they require that you are able to take apart the tablet unsolder the old port and then solder in the new one. There are several places that will do this as a service but it ain't cheap. One place shows $299 for board repairs. http://www.portatronics.com/index.php?cat=c295_Dell-Streak-7.html&XTCsid=vo7vc1f8r011l9e4p6e1bq34e3If you search for "dell streak charging port repair service" you may find one closer or cheaper. It is possible that you can find a good board by searching for streak repair parts. Make sure you know what replacement costs are for the unit. On some of these repairs you can come close to spending what you would for a new unit. So be careful about that.
My Dell streak 7 will power up but will only
During power up try holding the power button for 20 seconds. Repeat this three times. If still not working, connect tablet to your desktop or laptop and scan it if possible. Last option is from the desktop or laptop you should be able to reset to factory settings.
Want to know the dell streak 7 specification
Technical Details
- Android 2.2-powered mobile tablet with 7-inch multi-touch display loaded with entertainment and multimedia apps
- Enabled for T-Mobile's ultra-fast 4G network; Pay as You Go with prepaid and monthly data plans
- Rear 5-MP camera for photos and video; front-facing 1.3-MP camera for video chats via Qik service
- Ultra-fast Wireless-N Wi-Fi (with Wi-Fi sharing); Bluetooth connectivity; 16 GB memory; microSD memory expansion; multi-format media player
- Up to 4 hours of video playback, up to 72 hours (3 days) of standby time; released in January, 2011
See more technical details Product Features and Technical Details
Product Features
Dimensions
- Size (LWH): 7.48 inches, 4.74 inches, 0.47 inches
- Weight: 13.44 ounces
Product Features
- Network Compatibility: GSM
I don't know if this is exactly what you are looking for, but it's a starting point :)
Hi, I'd like to get an UNLOCK CODE for my Dell
Hello, first no one will give you free unlock code for your Dell Streak 7 except your network provider. You can ask directly to your network provider to get
Dell Streak 7 Unlock Code, but you must prepare a good reason why you need that code otherwise you will get a charge aproximately $80 for that unlock code. The other way you can buy
Dell unlock code from third party sites with cheaper cost rather than buy from official network provider. I hope my solution can solve your problem.
