20 Most Recent Sansui HDLCD3250 32 in. LCD TV Questions & Answers
There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
Sansui HDLCD3250... | Answered on Jan 03, 2018
Sounds like a main system control memory IC fault. Contact any service technician, or the authorized service center for Sansui.
Gopakumar Gopalan Google
Sansui HDLCD3250... | Answered on Mar 13, 2014
This is not the same model Sansui, but it is a tv.
http://youtu.be/qMpiC8YL3SE
Sansui HDLCD3250... | Answered on Feb 12, 2014
Leave it plugged in for about an hour for it to warm up than it will work like normal. I have this problem every once and a while
Sansui HDLCD3250... | Answered on Dec 26, 2013
Hi! I'm a little confused about what you are asking. Do you want to watch a movie from a USB flash drive or connect a USB device (DVD player, etc) to your tV? Please give a little more detail and I;d be happy to help.
Sansui HDLCD3250... | Answered on Nov 09, 2013
In older times, this would be something in the video circuit. I am sure that's what it is on your TV but I do believe it will have to be fixed in a shop.
Sansui HDLCD3250... | Answered on Oct 30, 2013
If you want to make a hard reset, just unplug the TV from AC wall outlet, and re-plug it back after 20 minutes of so. If you wish to make a system reset, you have to enter its service mode to do this. If you wish to get more details, check the site linked here
Selecting the view option, either to Mosaic / Time slide, can be selected by the drop-down list, at the top left of the display window, will make surf easy. You can also do a search, by type in the brand name/model number/IC used, in the search box at the top right of the display window.
Sansui HDLCD3250... | Answered on Oct 09, 2013
The main digital board stopped working. No SCL, SDA. Contact any service technician.
Sansui HDLCD3250... | Answered on Jul 01, 2013
Contact the autthorized dealer for Sansui.
Sansui HDLCD3250... | Answered on Jun 18, 2013
I get all my firmware updates from this site
Home Page
Sansui Televison... | Answered on Nov 14, 2019
I'm guessing a power surge from the returning power burned something up. You should have all your electronics plugged into surge protectors at a minimum. The best protection is a UPS (uninterruptable power supply).
Sansui Televison... | Answered on Nov 13, 2019
i'd like a nice coed too but young women don't usually go for old worn out men
Sansui Televison... | Answered on Nov 10, 2019
Already answered on your earlier post/
Short answer, analog probably not possible.
Maybe if you get a digital antenna and you have stations in your area.
Sansui Televison... | Answered on Nov 03, 2019
Hi Matt, for what you say the internal power supply of the Combo Sansui, 110 volts a12v, is not working
Indicate model of Combo Sansui, which you are commenting on, in order to find the best possible solution
I wait your answer
Regards Franco Dosil
Hola Matt, por lo que comentas no esta funcionando la fuente de alimentacion interna del Combo Sansui, de 110 volts a12v
Indica modelo del Combo Sansui, del que estas comentando, para poder encontrar la mejor soluci?n posible
Espero tu respuesta
Saludos Franco Dosil
Sansui Televison... | Answered on Oct 14, 2019
Sansui HDLCD3250 32 in. LCD TV Logo
26 questions posted
Top Sansui Televison & Video Experts
matt martin
matt martin
Ekse
Are you a Sansui Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Sansui Televison & Video
Most Popular Question
reset sansui factory settings
  • Televison & Video
