20 Most Recent Samsung DMT400RHS Builtin Dishwasher Questions & Answers
Over-level water error Samsung DW80F600UTS - ApplianceJunk.com
appliancejunk.com > ... > Forum Index > Dishwasher Repair
Dec 14, 2014 - 10 posts - ‎4 authors
Over-level water error Samsung DW80F600UTS. ... "heavy" lights flashing which my owners manual tells me is a "over-level" water error. .... Samsung DishwasherDW80F600UTS - High Temp Error (smart auto + normal lights). Samsung DW80F600UTS, drain code on
Jan 27, 2015
Samsung DMT300RFS/XAA OE Error
Apr 29, 2014
Samsung DMT400 over level water error
Oct 29, 2013
Samsung Low Level Water Code
May 14, 2013
More results from appliancejunk.com
Over-level water error - Fixya
Samsung... | Answered on Sep 10, 2018
Have you checked the water filter?
Samsung... | Answered on Jan 14, 2018
Your water level float is probably stuck. Take a look at this video and it shows you how to basically access this component. Use CLR to clean it out. Be careful to turn off your dishwasher breaker. Electricity and water do not mix well. Your dishwasher may be slightly different but Samsung dishwashers are pretty consistent in general as far as parts go. If you have at least basic mechanical skills you should not have any problem doing this repair.
Samsung... | Answered on Nov 28, 2017
Actually, if you look closely at that Low Rinse button or emblem, you will see a little lock symbol ABOVE the words "Low Rinse", and I'll bet THAT light is the one that is on. Basically, you have the control lock (or child-lock) turned on. To turn it off, you have to press and hold the SANITIZE button for 3 to 5 seconds until that light goes off. Now your dishwasher will work!
If you need further help, reach me via phone at https://www.6ya.com/expert/ronald_e6b9572cebe3ad27
Samsung... | Answered on Jul 20, 2017
try this , but will be a good idea to get service support from Samsung.
f your dishwasher is new--or if you have just replaced a door seal--the door may be difficult to latch for a week or two. If the tightness persists, though, try adjusting the latch, if it's adjustable. If it's not adjustable, there's probably nothing you can do immediately. But try running the dishwasher on the highest heat cycle to help the seal conform to the door. Otherwise, the seal should compress over time
God bless you
Samsung... | Answered on Mar 29, 2017
Actually, if you look closely at that Low Rinse button or emblem, you will see a little lock symbol above the words "Low Rinse", and I'll bet THAT light is the one that is on. Basically, you have the control lock (or child-lock) turned on. To turn it off, you have to press and hold the Sanitize button for 3 to 5 seconds until that light goes off. Now your dishwasher will work!
Samsung... | Answered on Mar 02, 2017
plugged spray bar perhaps OR not the proper kind of detergent .
Samsung... | Answered on Sep 09, 2015
The lights that are blinking are indicating an error code--the particular code you describe is a "heater error". You will have to check the circuit for an open heater element, loose or broken wire, defective main control board. The part number for the main board is DE92-02256C. Hope I helped you!
Samsung... | Answered on Aug 22, 2015
well they do burn out
Samsung... | Answered on Apr 13, 2015
Make sure your circuit breaker in the main breaker box has not tripped, or "poped". It will be one a little out of place and a bit loose if it has tripped. Turn it off and back on to reset. If it tripps immediately, you have a short somewhere, possibly in the dishwasher, so you will need an electrician and or Appliance tec. to find and fix.
Samsung... | Answered on Apr 10, 2015
It depends on what 3 lights are flashing. These lights are a code as to what is wrong, and how to fix it.
Samsung... | Answered on Mar 22, 2015
I believe that error code indicates that you've got a leakage error, which means water has leaked down into the base of the dishwasher. You'll have to pull the dishwasher out, pull off the side panels, and dry up all the water, but then you still have the problem of figuring out where the leak came from and fixing the problem before you can use the dishwasher. The most common source of leakage in a Samsung DW is the drain pump and/or drain hose.
Samsung... | Answered on Mar 11, 2015
It depends on which lights are flashing, because this is a code from Samsung to tell the technician what is wrong. So we really need to know which lights are flashing to answer your question.
Samsung DMT400RHS Builtin Dishwasher Logo
111 questions posted
Top Samsung Dishwashers Experts
vince
Marvin
Marvin
Are you a Samsung Dishwasher Expert? Answer questions, earn points and help others
View Most Popular
Samsung Dishwashers
  • Samsung Dishwashers
Most Popular Question
over level water error samsung
  • Dishwashers
