20 Most Recent
Coby Kyros Internet Touchscreen Tablet (MID7015-4G) Questions & Answers
Iam unable to turn it on, any help would be great
does the light come on when you plug in a charger? if so try turn it on with the charger in and on. and hold the power button for at least 5 seconds, if theres a light to indicate charge then theres power to it but could be some other fault internally, you have to try the tablet with the charger in and hold the power button for 5 seconds and you can leave the charger plugged in for an hour to see if it says charging just incase its a bad battery.
What is password located to get into wi fi. does it come from router
Yes, the individual who programs the router inputs a password of his or her choosing. When any device connects to that router it will be required to supply the same password before the router will allow you access to the Internet. The user of the device must manually input the log-in password once (it will be saved). If you know who programmed the router, you can ask them what the password is.
My android tablet is "frozen". Will turn on but
has anything been deleted from it when it has been plugged into a computer or has anything been deleted from the device itself from its root directory? if not and its gone like that by itself, it could be corrupted software or a missing root file which is usually bad at first, now what i know about some tablets is if it wont work theres a recovery file usually internally but this is in some tablets only that ive read about, i also have one but havent needed to try to restore it and it can be done from an engineering mode, this is possable by pressing the power button and another button like the home button at the same time once the unit is off untill it turns back on with options, but as for some models im not sure of but i will have to look this up at some stage as i am working on tablets at this time so unless you know what you are doing i wouldnt attempt it, once i have gotten through some tablets ill be able to give a better resolution on this subject with others. the advice ive given wont work for all as pressing power and home will start different options up on different tablets and versions.
