20 Most Recent
Dell Inspiron 620 ST Desktop Computer Intel Core i32100 processor (DDDNKT1) Questions & Answers
Dell 620s flashing yellow start button
Generally this means that it can't find the system disk. Most of the time if you press and hold down the power button, the computer will shut down. After that, restart and see what happens.
My dell 620 desktop computer just loss the audio
check if you have installed a software recently, remove it, or use rollback option from system management or also you can download the audio drivers and install them then restart. But i would advice you to follow the elimination steps i have put for you above.
Dell unstick power button on PC desktop
It sounds like either the push button assembly is broken on the front bezel cover, or the power switch is broken. Follow these steps to take the covers off.Front Bezel: http://support.dell.com/support/edocs/systems/insp620620S/Insp620/en/sm/bezel.htm#wp1181855Side access cover: http://support.dell.com/support/edocs/systems/insp620620S/Insp620/en/sm/cover_re.htm#wp1193123Now look for either a broken piece on the bezel push button assembly or a broken power switch inside the computer case.
How do you install a hard drive
Larry provides great answer up there ^^^ which is better down here.
Larry Ng Jun 23, 2022
NO PC told (dell has 10000 models)
no OS told, windows what"?
no drive told.
my wild wild guess is the boot drive is locked.
and you are attempting and ******* act. to it.
like deleting key parts of a running OS (windows) (like deleted tires on rims of 85mph moving car, fails)
no real goal told, but the nebular "install HDD"
one can add a 2nd drive easy or any of 1000s of external HDD models or external or internal, SSD or even a thumb drive. (vast) (just 2 steps in fact)
but the boot drive , change out is far far far more complex. and you never not told that.
you want to mess with the C: drive?
now let me guess the real goal (sad I must)
the OS drive windows is failing ( common)
and some lil' bird told you it needs a new boot drive, and then fail to say so here.
okay I will bite.
1: buy a new SSD (hdd fail and are slow)
2: buy a new OS, from MS. or get free w10. (ask how)
3: then put in new SSD,
4: run the w10 installer media (it is free)
5: load w10 to the SSD fresh
6: answer the silly 30 questions it asks.
7: and click activate. (buy it)
How do i change admin password
can;t log in now or what?
what does change mean,
lost it and now can not get in
or means just want to change it , logged in.
NO PC told and NO OS told
or if bios admin or windows admin.
bios or windows.
both are hacking./ if lost.
so google the cure.
How do i eject a cd from the laptop
push the physical cd drive try button marked EJECT
the PC must be running,
or use the paper clip hole trick. (if PC is dead or tray jammed)
google that. clip trick
the dell manuals covers this
How to delete bookmarks
google dead ?
first off my PC has 4 browsers.
all 4 different answer.
IE11 ( or OMG 1 to 10 )
Edge
Chrome.
Firfox v95 (click tab book marks then click manage BM, the right click any or all you see and delete.
learn google
like
google IE11 bookmarks delete.
and read, millions of hits world wide all true.
