20 Most Recent
Samsung ML1660 Laser Printer Questions & Answers
Paper jam how do i release it
if the jam was in the tray you should pull the paper slowlyand if the jam was inside the printer you should open the cover and remove toner cartdrige then remove paper and return toner cartdrige
Sleep mode
HI from the notification area in the taskbar of your computer open smart panel and from setting you can find it
ML 1660 error message - Sensor Failure #A-3112
This is an indication that the feed sensor is broken or just being block by an ink blotch or a small paper. If you are comfortable in opening your samsung printer, please check the sensors behind the paper feed rollers. Wipe them clean with a cloth with isopropyl alcohol and make sure it is clean.
Put the parts back together. Do not turn on the Printer yet. Press and hold the power button for 30 seconds (while it is plugged off the main power) and release it. Plug back the power and test your printer. Check if this will remove the error message. If not, consider yourself buying a new printer as this is not a replaceable part.
Hope this helps.
Samsung ML-2000
from where i can download printer driver for samsung ml-2000 series laser printer
