20 Most Recent Moultrie Game Spy M80 Infrared Digital Game Camera Questions & Answers
Trail card err
Please share some more information about your query.
7/23/2014 4:17:40 AM • Moultrie Game... • Answered on Jul 23, 2014
I have a M100 camera and it uses batteries in a day even with my moultrie power panel
Are you sure that power supply is coming fine from that power panel? Otherwise it should not use Battery.
7/23/2014 4:16:00 AM • Moultrie Game... • Answered on Jul 23, 2014
0answers
The mode stays lit up but no mode displays
contact moultrie. www.moultrie.org should know this fix.
10/13/2013 5:08:08 AM • Moultrie Game... • Answered on Oct 13, 2013
0answers
0answers
2answers
Display shows card error
Go to www.moultriefeeders.com...under mini cameras find the M80...open "full details"...scroll to bottom and find manuals/downloads...where it says upgrade click and download to your pc...be sure you download for your camera as Moultrie named all their camera downloads the same, but each is model specific...it will download as a compressed file.I use windows to extract file directly to NEW SD card installed in my PC's card reader slot.If your computer doesn't have a card reader, connect one thru a USB port.Once you have upgrade unzipped to the sd card, put card into the M80 and switch the camera to the "aim" position....should show "upgrade NO"..press up/down key to change to "yes"; press enter and wait...DO NOT TURN OFF CAMERA AND USE NEW BATTERIES...camera will turn itself off when done.Power on camera and test it out.This has solve the trail err and a few other issues with the M80.
10/11/2012 9:15:47 AM • Moultrie Game... • Answered on Oct 11, 2012
2answers
How to download pics to computer from camera. set
Don't turn cam on...just plug into an USB port and Windows should recognize it and cam goes into USB mode...a pop up should appear with options...use the picviewer option.
4/14/2012 3:03:29 PM • Moultrie Game... • Answered on Apr 14, 2012
I need to download the plot stalker software from
On the Moultrie website in the menu at top left click on minicams...opens to show the M80, M100, and another...I clicked on "full details" below ad for the M80; opened to caera details; scroll to bottom and click on software downloads...should show Plot Stalker M80, M100,I45...I have downloaded and extracted but haven't tried it out yet.
1/3/2012 3:37:42 AM • Moultrie Game... • Answered on Jan 03, 2012
How to down load upgrade to card
Can you specify what type of upgrade you are looking to download?
12/23/2011 4:36:27 PM • Moultrie Game... • Answered on Dec 23, 2011
Moultrie m80 5.0 camera will
had to program mine thru setup menu for mode I wanted to use..pressing mode and hold several times works sometimes.
12/17/2011 4:00:42 PM • Moultrie Game... • Answered on Dec 17, 2011
Im a getting a card err read on a brand new
try another card...these M80s are sensitive about SD cards, and a card used in one device won't work in another M80???Do the SD101...Check the write protect switch on side of SD card; make sure card slot has no debris or bent pins...blow it out with duster or contact cleaner.
12/17/2011 3:57:11 PM • Moultrie Game... • Answered on Dec 17, 2011
Camera worked great the first
O.K.,I assume you use two SD cards, take out the one in the camera, put a blank one in the camera,and bring the one that was in the camera home to review pics on your PC...unless you have a laptop you carry to the field with you.Either case, you viewed SD card and nothing...switch on side of card pushed forward toward contacts?Always deleted pics using camera's delete function..NEVER DELETE USING PC;NEVER FORMAT USING PC;...Moultrie says to only use high quality SD's...recommend Sandisk or Lexar...I never had problems with any SD as long as I stay with name brands...I find I have accidently moved write protect switch; deleted before thought from PC...or PC says card needs formatting before use...DON'T..this is just PC not recognizing card's format..try different cards,they do get corrupted...make sure card insertion slot is free of debris...blow it out with contact cleaner/duster,ect....then the M80 has a software upgrade from www.moultriefeeders.com.
12/16/2011 3:56:18 AM • Moultrie Game... • Answered on Dec 16, 2011
Its a M60game spy. night pics are blank and camera so sensitive that all pics are taken in 2 days or less, batteries are good about 1600 pics ??
I hear Cuddyback makes a good camera. Moultree can't seem to keep theirs working and don't care if they work.
8/16/2014 5:56:24 PM • Moultrie Home... • Answered on Aug 16, 2014
Moultrie Game Spy M80 Infrared Digital Game Camera Logo
Popular Tags
32 questions posted
Top Moultrie Home Security Experts
ADMIN Eric
ADMIN Eric
ADMIN Andrew
ADMIN Andrew
Are you a Moultrie Home Security Expert? Answer questions, earn points and help others
View Most Popular
  • Moultrie Home Security
Most Popular Question
  • Home Security
