20 Most Recent Symbol PDT 6846 Portable Terminal Questions & Answers
To configure the terminal Ctrl-C to drop you to a DOS prompt then type cfg11 this will then take you a configuration screen where you can enter wireless and IP settings.
I can’t say about what program you are trying to load. If you get the system to associate then the next step is to configure the host settings.
FUNC-CTL-R at the Connect to Host screen
Password: system
Then you can add host settings.
It’s a shame we fix PDT6846's all the time and if we replace the board reconfigure them for the customer.
If you need any more help then please do not hesitate to contact us:-
http://www.biastechnology.com/
or TEL 01202 620955
Symbol PDT 6846... | Answered on Apr 07, 2015
Hi
Contact Motorola Solutions Get Support or Zebra Technologies
Support Downloads. They aren't helping on FixYa yet so it is best to reach out directly.
Mark
Motorola Mobility Support
Symbol PDT 6846... | Answered on Jan 19, 2015
this is a cars and trucks forum
Symbol PDT 6846... | Answered on Sep 12, 2013
it depends on the type of imager - sounds to me like you have the red dot/green dot scan engine. Its not possible to change it back
Symbol PDT 6846... | Answered on Nov 24, 2011
is it on boot craig?
Symbol PDT 6846... | Answered on Nov 17, 2011
This could happen if:
  • PDT6846 is operating with battery at less than nominal charge level (lower than normal power output).
  • Possible defective radio card.
    The PDT6846 configuration is not the issue here, as the unit will associate once within range of the access point. If the PDT6846 fails to connect when roaming out of the primary access point range, and relocates to an adjoining access point's cell, this problem is indicative of either an internally defective RF card or simply a weak signal output from the PDT6846 due in large part to a weak battery.
    1. Verify PDT6846 is operating with a fully charged battery.
    1. Warm boot PDT6846 to reestablish radio association.
    If problem persists, the PDT6846 requires repair attention specific to the internal radio card.
    Thanks!
Symbol PDT 6846... | Answered on Jun 15, 2011
You cannot access C: Drive as this is the eprom of the device and is not accessible. If it shouws the D: prompt it is because it has no applications loaded. Let me know exactly what do you want to do and i will help you.
Symbol PDT 6846... | Answered on May 27, 2011
It can only be one of two things.
Less likely but also will cost you nothing, try and reload LWP and UPD but don't forget to use the comman FLSHFMT on both E drive and D drive first.
More likely is that the radio card of the terminal is busted or might have become lose as the internal radio connector was always a bit flakey on this device. You can try removing the 6 screws on the plastic cover, open it and unplug and plug again the radio card.
Symbol PDT 6846... | Answered on Dec 21, 2010
is there no message on the scanner absolutely?
Symbol PDT 6846... | Answered on Jun 19, 2010
Symbol PDT 6846 Portable Terminal Logo
52 questions posted
Popular Products
Top Symbol Computers & Internet Experts
Ekse
Vish Iyer
Vish Iyer
Thomas F. Schneider
Are you a Symbol Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Symbol Computers & Internet
Most Popular Question
quickbasic compiled program run symbol
  • Computers & Internet
