20 Most Recent Acer ICONIA Tab W500PC52G03iss Questions & Answers
Just a quick try - make sure that the plug is securely in the wall socket - and the back of the TV, if it has a removable cord. The next suggestion would be to make sure that all timers are off. the last thing to look at is ventilation and to make sure the unit is not right on top/close to a heat source. All basic suggestions, but sometime we overlook the simplist things.
Acer ICONIA Tab... | Answered on Feb 09, 2015
go to www.google.com
in the search enter: iconia tab activation
hit enter
chooce how activate an AT&T plan....
follow the directions.
if it is another carrier call that carrier and they maybe able to help you.
Acer ICONIA Tab... | Answered on Dec 12, 2014
Perform a Factory Data Reset of Acer ICONIA
The following steps will erase all of your personal information, all stored contacts and any programs you have installed on your tablet.1.Power off the tablet.
2.Press and hold the Volume up button, which is located closest to the touch screen lock switch.
3.With the Volume up button held, press and hold the Power button for 3 seconds then release it. Continue holding the Volume up button.
4.Once the tablet vibrates, switch the touch screen lock switch on and off repeatedly while still holding the Volume up button.
5.Release the Volume up button and stop switching the touch screen lock switch once the "Erasing Userdata..." message appears in the upper left corner of the screen.
6.Once the factory reset has been completed your tablet will load to the Welcome screen. 7.Your Factory Data Reset has completed now follow the onscreen steps to setup your tablet.
Acer ICONIA Tab... | Answered on Jul 06, 2014
Hi, you certainly need to remove enough data/programs to allow for the new operating system. You should be able to copy these to a usb stick, delete them from the Acer,and then when the new system is installed, reconcile your data/programs and copy back what you can. The easiest to remove is data eg photos, music/movie files. Cheers.
Acer ICONIA Tab... | Answered on Nov 16, 2012
Power down. Hold power button for 5 sec. Should reboot
Acer ICONIA Tab... | Answered on Aug 28, 2012
Face book games require javascript and flash to work. You can try going to the market and installing both but i'm not 100% sure the stock browser will work. And if you have a alternate browser such as mozilla then you ned to install flash etc for that. Now you run into one of the android quirks is that it will only link flash to the fist thing installed and if you open say mozilla to install flash from the market it just says installed and does ot give the install option. So what you have to do is unistall it from the tablet reboot then reinstall it using the browser you wan it in.
Acer ICONIA Tab... | Answered on Mar 23, 2012
I know how to log out. Go to your name on the right upper corner. Click the drop down menu.
Acer ICONIA Tab... | Answered on Mar 13, 2012
Go to acer.com click on support then download. You next need to select your device to go to its support page. Tablet, then Iconia Tab then W500P then click on image of your tablet. Under DOCUMENT scroll down to find the user manual. You have to scroll down or it doesn't show on the listing. Click on the orange download button at the left of the line listing and the zipped user manual ile will start to download. Your browser will either ask where to save this to or will put it where you have specified under browser options. I you save it to a place you can recall or to your desktop then you can extract the files usually just by clicking on them. Inside will be a pdf file which is your user manual which you will need something like Acrobat reader (free from Adobe) to use to read this file. If the second part of this works that will be the direct link to the user file and you might be able to download it using that.
http://global-download.acer.com/GDFiles/Document/User%20Manual/User%20Manual_Acer_1.0_A_A.zip?acerid=634378292522483553&Step1=Tablet&Step2=ICONIA%20TAB&Step3=W500P&OS=722&LC=en&BC=Acer&SC=PA_6
Acer ICONIA Tab... | Answered on Mar 07, 2012
On my Iconia when I see this show up it will be from a low power or a poor wii connection. Basically the signal strength is too low which means the speed drops to the point where everything is timing out before it gets loaded.
There are a couple o causes to check . One is too far from the wifi router.the farther away the lower the signal the slower it goes. You have objects blocking the signal such as steel reinforced safety windows or steel mesh in walls. These can block the signal. I have one are where I'm all of 10 feet away and it will barely connect. I have to move about three feet to the side and get ull strength and speed. The orientation of your tablet can effect i you can use a marginal signal or not. Try aiming the edge with the volume buttons towards the wifi. The antenna is oriented in a way that this will slightly improve the signal. The other thing is that your tablet can be fine but your wii router is having problems with its wifi sections. Certain brands will show more errors and then difficulties in connections in as little as a year old (on some about half that). The Iconia has a rather good wifi ability so I wouldn't blame its hardware but would look at the location orientation etc as I have mentioned.
While still holding the Volume Up button, press and hold the Power key for 3 seconds then release it. Continue holding the Volume Up button. Once the tablet screen turns on, stop holding the buttons. From the menu choose "Wipe Data/Factory Reset" by using Volume buttons to scroll and Power button to select options.
Hard Reset ACER B1-730 Iconia One 7 Tab - HardReset.info
https://www.hardreset.info > devices > acer > hardreset-first-method
Acer Tablets &... | Answered on Oct 22, 2019
You should be able to go to Settings, then locate Apps, then Kindle in the list of Apps, Then Uninstall Kindle.
Acer Tablets &... | Answered on Apr 13, 2019
Acer ICONIA Tab W500PC52G03iss Logo
Popular Tags
26 questions posted
Top Acer Tablets & eReaders Experts
 Mike M
Mike M
Kurt Bresler
Are you an Acer Tablet and eReader Expert? Answer questions, earn points and help others
View Most Popular
  • Acer Tablets & eReaders
Most Popular Question
acer iconia android tablet refuses
  • Tablets & eReaders
