20 Most Recent Toshiba Thrive Android Tablet Questions & Answers
iTunes is only for devices such as iPhones, iPads, and computers (Mac/PC) and will not run on an Android tablets.
Hope that that helps!
Toshiba Thrive... | Answered on Jan 14, 2020
make sure your wifi network is turned on, then open your tablet's wifi and search for it. it should be fine, if not, contact Toshiba for tech help.
Android 4.0 Tablet PC
Toshiba Thrive... | Answered on Jan 12, 2020
To clarify - you are entering the username and password of the internet website from which you wish to purchase something.
1. Presumably you have previously registered with this site and have now forgotten the login details.
2. Click the 'Forgot my password' link - they will send you instructions to reset the password.
Toshiba Thrive... | Answered on Feb 04, 2018
Cookies and Browsing history may be deleted using the Privacy Settings in the Android Operating System. Simply click on the Settings icon, then go to Privacy Settings. On the right you will be able to clear cookies, cache and browsing history.
Toshiba Thrive... | Answered on Jan 06, 2015
Try editing it. That will give you the opportunity to change it.
Toshiba Thrive... | Answered on Oct 01, 2014
This has nothing to do with the game, but with the tablet. This a very resource intensive game, and if your tablet does not have a fast enough processor or ram, it will keep freezing.
Toshiba Thrive... | Answered on Feb 02, 2014
Candy crush is very resource intensive and meant for newer android versions, there is nothing you can do but upgrade your device.
Toshiba Thrive... | Answered on Dec 01, 2013
reset your router, then restart tablet, then try logging on!
Toshiba Thrive... | Answered on Nov 14, 2013
This normally means there is a problem with the operating system, it normally means its necessary to restore its factory settings. You can do this two ways either follow these instructions:
A.
  1. Turn off tablet
  2. Press and hold the "+" on the volume key
  3. While continuing to hold the "+" volume key, press and hold the power button
  4. Tablet will start (and let go of both buttons at this time) and will give your 3 Icons. Using the volume key, select the middle Icon of the box with the arrow coming out of it. The power button is used as the "enter" key
  5. On the next screen, arrow down to the wipe data/user info clean and factory default and hit the power button. PLEASE NOTE, THIS WILL WIPE OUT ALL SETTINGS AND INFORMATION YOU HAD ON THE TABLET.
  6. On the next screen, select Yes for wiping all info and restore to factory.
  7. Once this is done, select reboot and you will be brought to the initial set up.
If that doesn't work, you might have to manually reinstall the operating system which should be Android 3.0 (Honeycomb) which you can follow this link. http://www.addictivetips.com/mobile/root-toshiba-thrive-honeycomb-3-2-1-ota-rom-us-and-canada/
Toshiba Thrive... | Answered on Oct 27, 2013
If you need more details just click this link now : http://www.mtsdelhi.in
Toshiba Thrive... | Answered on Sep 12, 2013
como desbloquear mi tablet
Toshiba Thrive... | Answered on Jun 08, 2013
It means your browser is full of cookies and they needs to be cleaned. Check Tool menu.
Toshiba Thrive... | Answered on Mar 03, 2013
With a heat gun and a plastic pry bar.
Toshiba Thrive... | Answered on Feb 02, 2013
Toshiba Thrive Android Tablet Logo
127 questions posted
Top Toshiba Tablets & eReaders Experts
Ekse
Alun Cox
David Jercinovic
David Jercinovic
Level 1 Expert
Are you a Toshiba Tablet and eReader Expert? Answer questions, earn points and help others
View Most Popular
  • Toshiba Tablets & eReaders
Most Popular Question
39 t turn tablet
  • Tablets & eReaders
