20 Most Recent
HP Omni 100 PC Questions & Answers
Removing viruses
HOW TO
OR SHOW AND TELL.
PC TOLD ME IT IS DOING THAT, SURE.
OR WHAT,
TELL THE STORY
WE WAITED FOR 6 YEARS.
Why did my omni 100 disply screen shink, how do I fix it
ATI Radeon HD5450 graphics processing unit (GPU) soldered to the motherboard
Figure 3: GPU with fan - Interface: GPU chip soldered onto motherboard
- Maximum resolution:
- HDMI TV resolution: up to 1080p at 60 Hz*
- HDMI PC resolution: 2560x1600 at 60 Hz
- DVI TV resolution: up to 1080p at 60 Hz*
- DVI PC resolution: 1920x1200 at 60 Hz
- VGA resolution: 2048x1536 at 60 Hz
You need to use the ATI Catalyst Control Center software to optimize display. See this page for the Omni 100 drivers See
HP Support
Pc wont power up has blue logo screen
without further information this is impossible to solve, reboot to safe mode if possible then back to normal mode will sometimes fix this, otherwise reinstall
Video Problem
That seems to be the monitor running a test. It might do that if it isn't receiving a signal from the computer. Make sure the cable is plugged into the tower and the monitor.The graphics card could be bad, or the motherboard or power supply. Has it ever worked before? What changes were made? Was there lightning in the area or a power failure?Turn the computer off and unplug it, and the monitor. Wait a few minutes, then plug everything in and restart. Hopefully it isn't a permanent hardware failure.A test to narrow down the cause would be to use a different monitor or computer to see where the problem lies.
